Xtreamer Multi-Console = MINIX Neo X7?
    Hi guys,
    Xtreamer has released news about their new multi console, when I saw it I thought: hey that's an X7!!
    Same look
    Same specs (although they mistyped. RK3188, they claim RK3818 which does not exist)
    Same WiFi receiver
    Same android version
    It seems to me they are selling a rebranded x7?
    I take this as good news - new firmware possibilities
    I found a new firmware by Xtreamer
    Updated ROM link: http://download.xtreamer.net/Firmwar...consoleROM.zip
    Seems to be a 720p kernel - but it probably has interesting improvements?
    Website says:
    Airplay & DLNA by Airpin
    Busybox
    Clockworkmod Recovery
    Root Access
    Init.d Scripting
    CIFS mount
    XBMC Plugins & Repo
    OTA Update
    Setup Wizard
    Kids Mode
    Tweaks:
    Gameloft
    nfs support with auto-mount on startup scripts
    build.prop tweaks
    patched libmedia.so for DTS
    Patched Kernel
    I wonder if anyone can check wether this is compatible with X7 or X7 Mini, we seem not to be sure
    What do you think ?
    Last edited by Guest; 15 January 2014, 12:08. Reason: Combined both Posts in 1 thread
    Updated first post with more info
      It's the x7 mini firmware modded look the name of the file
      2014-1-7_x7mini_6330 Xtreamer 720p.img
        So i found the proof :
        I wonder if there is any added benefit to their firmware, how do we go about unpacking a rom and looking inside?
        I updated the correct link for the rom
          The Xtreamer rom contains XBMC for Minix (v12.4.0) and the buil.prop contains "ro.product.model=NEO-X7-mini" it was created the 7th of januari 2014.
            I quite like the look of the launcher they have. If we could pull the Rom apart and get it, I would use it with the KitKat Rom
            Sent from my Nexus 5 using Tapatalk
              price of the xtreamer is alot higher. so no reason to buy a rebranded minix..
                Can someone extract the xbmc apk so i can try it on the minix x7??
                  It is better to install minix xbmc beta 2...it is the same! And people in other forum tell that xtreamer is x7 mini! Stay away from funny sellers!
                    The xbmc included in this rom is identical to the one that was included in the 008 release. I have already looked at it.
                    To Infinity and Beyond.... XBMC
                      has anyone tried to flash this onto there minix x7?
                        I decompressed the system.img of xtremer multi-console but I don't find the xtreamer launcher apk.
                        The UI is really this?
                        Do you know the correct file name?
                        Lupin4
                          its not always just the box
                          its very much what you pack inside it
                          for what it looks like, they did a great job optimizing "desktop" and packed some things i personally would like bundled, like retro games and out of the box radio etc..
                          if its all smooth and working, its ok to add price for the time i have to save getting it all together.. imo
                            true.
                            I also unpacked the firmware available on site and it was a stock X7mini
                              The new xtreamer firmware (exit same days ago) is completly different and inside there are many new app.
                              Tommorrow I'll try to install launcher in my t428.
                              Stay tuned.
