I'm new to this forum and I'm astonished by all the hard work made by this community to improve our Android devices.
First of all, a big thank you to all of you!
I've recently bought a CS968 (CR11s) box, but unfortunately I'm somewhat disappointed with it.
Now on a 1080p ROM, the Android UI is laggy and XBMC doesn't play fluidly any video above SD resolution, and even that with video and audio out of sync.
Fot the past 7 days I've tried every combination of ROM (for CS968) and XBMC, but to no avail. Yes, I know, MX Player works just fine, but XBMC is the main reason I wanted a dedicated media player and I'm not going to change that. And yes, I know justXBMC works great with MX Player, but again, I can't use the Subtitles addon and some other stuff native to XBMC.
In a desperate move, last night I've flahsed levvy's HFW for CS918 on my CS968 - I wasn't expecting it to fully work, or even work at all, but I didn't know what else to do.
To my surprise, the box booted just fine and the performance was INCREDIBLE. Almost no lag in the Android UI and the XBMC experience was almost perfect. It still suffered from minor frame drops during 1080p playback, but totally watchable, and 720p and SD were flawless and audio/video in perfect sync.
Unfortunately (in fact, as expected, based on the HW differences), only 2 USB ports were functional, and no camera, IR, bluetooth, wifi or ethernet connectivity.
So now I'm a little confused.
What do you guys think I should do?
Is there even a remote chance of having one of the great modded ROMs out there ported to CS968?
Has any of you managed to fix your box through a miracle combination of ROM and XBMC build?
Or should I just give up, sell it and buy a Minix X7 instead?
Thank you all for your time and I'm eagerly waiting for your replies.
