What is the best input device
    I'm currently using a Bluetooth mouse and keyboard to control both of my MK809III's. It works fine but I'm curious what others are using. I was thinking about getting a fly mouse and maybe one with an integrated keyboard. If I was to go with two 2.4G input devices of the same brand they will be a room apart from each other, could they interfere with each other?
    Anyone have recommendations on what the best choice would be.
    HK1 Pro Plus
    FlowFon F1
    H96 Pro+ (Wisdom-Green Board-2017-02-10 H96-S912-TVBOX(DDR4)-V0.2)
    MXQ Pro+
    R-TVBOX Mini+
    MK809III
    I'm using a flymouse "Unotec Flypad" (which is exactly like this one from DX) and it's really great to use it on the TV in a confortable way. I think I wouldn't use my mk802iv as much as I do now if it wasn't for the airmouse (bt mouse+keyboard is annoying to use in the couch).
    Regarding the interferences, I can't help you.
      Thanks, I'll consider that remote. I like the idea of Bluetooth, no dongle taking up a port.
      HK1 Pro Plus
      FlowFon F1
      MXQ Pro+
      R-TVBOX Mini+
      MK809III
