9.7in Quad Core Retina CEROS REVOLUTION
    I would appreciate any help with rooting this Tablet.
    I need to run a 21mbps Dongle and it will only run the HUAWEI E1750
    The manufacturer says that it can't be rooted..... I am hoping this is wrong.
    Here are the specs:
    Operating System: Android 4.2
    Hardware Chipset: CPU RK3188 Quad-core ARM Cortex-A9
    GPU Mali-400 MP
    Speed: CPU 1.6GHz
    GPU 533MHz
    RAM: 2GB
    Screen: Third Generation HD 10 Point IPS Retina Screen
    Screen Size: 9.7 inches
    Screen Resolution: 2048×1536 264PPI
    Ports/Slot/External Sensors: Micro SD Card Slot
    3.5mm Audio Jack
    Speaker
    HDMI
    Micro USB
    DC IN
    Internal Memory: 16 GB
    External Memory: Micro SD Card up to 32GB
    Battery Life: About 6-7 Hours (Depending On Usage)
    Standby Time: 72hrs
    Battery capacity mAh: 8000
    Camera Resolution: 0.3MP Front Facing Camera
    5MP Back Facing Camera
    Picture format: JPG, GIF, BMP, PNG
    Video format: Mpeg1, Mpeg2, Mpeg4, SP, ASP, GMC, XVID, H.263, H.264, BP, MP, HP, WMV7/8/9, VC1, AP, VP6/8, AVS, MJPEG
    Music Formats: MP3, WMA, FLAC, AAC, WAV, OGG, MP2, MA4
    WiFi: YES (B/G/N)
    3G: YES (Via USB 3G Dongle)
    Bluetooth: YES
    Languages: Afrikaans, Bahasa Indonesia, Bahasa Melayu, Dansk, German, English, Spanish, French, Italian, Magyar, Dutch, Polish, Portuguese, Vietnamese, Turkish, Greek, Russian, Arabic, Thai, Korean, Chinese (Simp), Chinese (Trad), Japanese
    Certification: CE, FCC, RoHS
    Dimensions (mm): 240 x 187 x 9.8 (L x W x H)
    Thank you
    Regards white jade
    Root Ceros Revolution
    Originally posted by white jade View Post
    Here are the specs:
    GPU Mali-400 MP
    Speed: CPU 1.6GHz
    GPU 533MHz
    RAM: 2GB
    3.5mm Audio Jack
    Speaker
    HDMI
    Micro USB
    DC IN
    Standby Time: 72hrs
    WiFi: YES (B/G/N)
    Bluetooth: YES
    Thank you
    Regards white jade
    Try Kingo root.
    Worked on mine.
      Originally posted by Gador04560 View Post
      Try Kingo root.
      Worked on mine.
      Thank you but, the problem has already been solved with the kind help from members on here.
      Regards white jade
        Regards white jade
        No worries, glad your sorted.
