How to put this arnova 9g2 into recovery???????
My instruction in my ROM should tell you how to do it. I did not write that for the 9G2 because I do not have one. A user supplied the instructions. But since many have follwed them I assume they are good instructions.
Hopefully someone with a 9G2 will help you.
Originally posted by yggdrasil_232 View PostHi guys, I just ask it 'cause I have to installe the finless's rom 1.5 for a friend of mine but I don't just get how to put that tablet into recovery. I tried so many times and maners that I am quiet lost. Please help me guys.
- put the tablet into download mode
- install the USB driver
The problem I faced when trying to do this for the first time is that when the tablet is in download mode, the tablet seems to be OFF. You do not see anything happening on your tablet at all: no sound, no blinking led, no messages, nothing... But while in download mode, the PC can see the USB device, so you can install the drivers and run the flashing tool.
For me the simplest way to put the tablet in download mode is basically to use the Reset button while you are pressing the Menu button as follow:
- have the tablet OFF
- press "Menu" and keep it pressed
- press and release "Reset"
- release "Menu"
This is how I do it:
- with the tablet ON connect Tablet and PC through the USB cable
- switch OFF the tablet
- use the Menu+Reset button and go into download mode
Now you are in download mode, install the USB driver and the flashing tool should work.
Edit:
connect the PC and Tablet through USB cable before putting the tablet in download mode
There are currently 1891 users online. 0 members and 1891 guests.
