Everything WAS fine and when I pressed UPGRADE it started 'till about 25% and FAILED. I tried 3 times and every time was same
I tried followed this tutorial...so when goes wrong 3rd time I read it to the end of text (my job is IT and i know much things about flash etc...) and saw LAST SENTENCE. Marked red. But LAST one, not in the beginning of text! So why last?? Do not turn on “ USB Debugging “ in the setting when upgrading firmware.
So you know already...USB debugging was turned on in my case.
And I unplug tablet from computer and try to power on, but NO WAY! Just turn on balck screen with PIPO 4.2.2 words and numbers in the middle of screen and 2 icons in lower right corner (android and graphic chip).
So I can't do ANYTHING with tablet now
I can put it in Recovery mod (vol+ and on/off), but can't flash anything from recovery. Dont recognize any .img file and don't want to flash .zip file. Just sait falid, failed, failed
I try to flash RileyROM 1.1...ROM flash tool, CWM...does not work. Install RokchipDriverInstaller (.exe file) but can't see it in Dev. manager because can't recognize tablet.
Tried vol- + reset...nothing happened.
Please...need help.
