KitKat-4.4.2 for Minix X7 by Strauzo
    I started to play with android 4.4.2 on RK3188 and I want share this rom that i use on my Minix X7.
    Version 1
    1080p cpu 1.7 ddr 667
    all 3 usb working
    volume +/- solved
    wifi, bluetooth, ethernet working
    very good video decoding in xbmc and in all other video player also for 1080p videos
    root
    busybox
    init.d
    antutu score 21200
    DroidMote work very well.
    Link download:
    <DELETED>
    Kernel with stock hardware remote control support <DELETED>
    A special thanks to BOB Finless that support me in every post.
    Thanks for your rooted rom. I have tried your rom and have some things to say:
    - good performance and nice appearance
    - can't use back button with my mouse
    - do not have lan network. only wifi ethernet available
    I have some things like that. Hope your best soon
      Is there any difference from Wassers KK rom?
      Sent from my Nexus 5 using Tapatalk
        Lan work very well for me. Disable wifi and enable ethernet in setting -> more -> ethernet
        Open the screenshot below:
        Update:
        If you mean you can't access windows share on network, copy the file linked below in folder /system/etc/init.d
        <DELETED>
        add permissions 700 to this file:
        su
        chmod 700 /system/etc/init.d/95cifs
        in the /system/lib/modules folder you can find also other usefull modules for the kernel
          apart performances and newest kitkat rom, all 3 usb working, volume +/- solved.
            Next step for kitkat roms is passthrough audio support for XBMC
            tode
              Does this ROM support mounting multiple USB storages? How about changing the audio device through the Android settings?
              NVidia Shield TV 2015 16 GB || Stock
              NVidia Shield TV 2017 16 GB || Stock
              Buy me a beer?
                With the app USB OTG Helper free https://play.google.com/store/apps/d...l.usbotg&hl=it
                you can mount many usb devices simply. (tested with two usb flash drives) You find your usb drive unders /device/storage/UsbOtgDrives if you are using es file explorer.
                For audio switch you can use SoudAbout.
                This is a standard android rom, all that work on a tablet work also on this rom in the standard manner. android standard what i like.
                But for now i'm testing performances, stability, wifi, bluetooth ethernet. (the base things)
                i tested also video rent from google play movies and it work very well.
                  What do you mean by standard ? Is it AOSP based ?
                    very very close to aosp.
                      I understood that it was close to AOSP (that's what standard means in Android ROM development), the real question is : is it based on AOSP code or is it based on leaked rk3188 4.4.2 code ?
                        The leaked sdk 4.4.2 is not complete, is in young state and contain many errors. I compiled one from the leaked sdk, but you have a not complete rom like the first kitkat rom on mk908. This rom shared by me have all the new closed source prebuild library related to hardware components of your device. All the leaked source code have inside prebuild binary closed source that are the most important part to optimize a firmware. Without this source code also with the sdk you can't do more. The only one way is to grab this from big tablet manufactures and adapt in your rom. With sdk you can change only the android related part but not the part of software that communicate with the hardware / kernel. HAL components.
                        Rockchip sdk is a thing that permit the personalization of the firmware of manufactures. Only big company have the source code of the hal components. (The best part)
                        The open source part of rockchip sdk is the already open source of android AOSP (with little modifications for this rom and many bad modifications in case of old 4.2.2 chinese roms). Android is a strange beast is open source for same parts but can be closed source for the best part that permit android to run on your device.
                        My hard work on this firmware was adapt the new 4.4.2 kernel source to the minix devices. But i can do many other improvments.
                          As you should know this is something that most people know (we are on freaktab ... this is not a forum meant for lambda end users).
                          You could just have answered that this is Pipo stuff (and all the crap it provides) on top of your self-compiled kernel for minix x7.
                          Althought you could have added to your log that it doesn't support the IR remote nor external webcams.
                            Sorry but your question is a question of a lamda end user. in future release of the kernel i can also add the little hardware remote control, not very usefull for me and all the webcam that you want (instead usefull ).
                              hi
                              question --> will i can use my remote with this rom?
                              ---> 2.4 GHz Rii i6
                              http://www.****.de/itm/350789122620?ssPageName=STRK:MEWNX:IT&_trksid=p398 4.m1497.l2649
