Polaroid AS8 SOUND Problem
I have a New Polaroid AS8 Tablet just bought at Christmas all was well , did the update that was suggested by store , after around 4 days after update ( don't know if has anything to do with problem ) But i lost all sound . I go into settings and there all things say all is well everything is checked that should be and shows everything is well ... But when i go to touch screen to adjust sound menu comes up but can not adjust nothing and as well the blue line is there and the lighted ball isn't bright it is a dull blue and volume doesn't work on touch screen... Can someone help please to give me a up how to fix the sound thanks. -
Originally posted by IronHorse View PostI have a New Polaroid AS8 Tablet just bought at Christmas all was well , did the update that was suggested by store , after around 4 days after update ( don't know if has anything to do with problem ) But i lost all sound . I go into settings and there all things say all is well everything is checked that should be and shows everything is well ... But when i go to touch screen to adjust sound menu comes up but can not adjust nothing and as well the blue line is there and the lighted ball isn't bright it is a dull blue and volume doesn't work on touch screen... Can someone help please to give me a up how to fix the sound thanks.
Here is the update i installed
Originally posted by guessyet View PostWhat update did the store advise you to do?
Originally posted by jimn2tdi View PostThere are new updates for the A/S series tablets.
http://southerntelecom.com/polaroidsupport/updates.html
Originally posted by cholzsch View PostActually, that's my issue. I got the AS10 for my son for Christmas from Kohl's, and after he used it fot awhile I did the update from Sothern Telcom. Since the update, no sound is available (just the dimmed volume bar).
Originally posted by jimn2tdi View PostThere is the update dated 090913 and the latest one dated 012414. I have both img files.
There are currently 2318 users online. 0 members and 2318 guests.
