Greetz to Finless Bob & Dark4u
Bricked UG802 V2 No Wifi (Fixed)
Hi
Extract the the kernel from mine replace finless one with my kernel then reflash. Try that
Originally posted by julian999 View PostThis rom wifi works OK, but resets when I run XBMC or Antutu and cpu is very hot.
Too bad because the finless 1.7 beta3 rom I almost never detected wifi
It would be perfect if they could get the wifi drivers in this rom finless 1.7 beta 3 for clones
Your firmware is the only one which gets my wifi to work, thanks !
But system reboots when I use openvpn
I wanted to use your kernel in finless 1.8 but can't seem to find how to extract the kernel.
Can you point me to a method to extract the kernel from your firmware ?
Originally posted by Mtype101 View PostExtract the the kernel from mine replace finless one with my kernel then reflash. Try that
Reupload Please
Originally posted by Mtype101 View PostPlease Try my Fw its based on UG802 V2 if you have realtek wifi module this should bring your wifi back to life.
^ Please Reupload This Mtype101^
Can you upload this FW again??
Man thanks
There are currently 2557 users online. 0 members and 2557 guests.
