HOW TO FLASH BACK TO OO8 ORIGINAL FIRMWARE FOR MINIX MINI X7
    Hello guys an girls,
    i want to flash back from neo rom to original.. (Tried both nitro and neo good roms!! but to much bugs for Know) The only problem is that both neo and nitro use rk 1.37 flash and for the original rockchip 1.7 flash.
    When i flash back kernel stays the same so no original kernel. can somebody help me with this??
    greetz giorgio
    greetz giorgio
    I just did it this morning from the Quickshot V1 and an overclocked 720 kernal.
    I downloaded 008 from Minix and there is a flash tool in the package called RKBatch tool. Use it. Plug in your USB cable, Make sure you use a pin or paperclip to press the reset in and hold the power button down for a few seconds. When you do that the RKBatch tool will recognize it. An icon will light green on RKBatch.
    I always have a HDMI cable plugged in to watch the reboot progress on the tv at the same time.
    Within a few minutes 008 was upgrading to 009. I left it and went for a run. When i got back 009 was installed.
