Best ROM for PipoM9 Pro
I will let the users chime in on that one...but I think the Finless ROM is the most stable. My KitKat ROM isn't for beginners. There are too many things that Pipo needs to address in KitKat.
Sent from my SAMSUNG-SGH-I537 using TapatalkRandy
Originally posted by ludoke View PostIn my opinion Finless 1.5 is the best ROM for it and battery friendly.Originally posted by skippie View Postyes I agree.
Battery life is amazing : 8 to 10 hours of constant use.
sent from ONDA V972
Does it go to deep sleep?
It depends on what your definition of "best" is.
My KitKat ROM has its flaws, but there are reports of increased performance. There is no GPS support, though...and multi-user doesn't work. Some other rarely used functions are missing. You just have to do your homework before you flash, because you can easily brick your tablet if you don't flash the loader.bin. Same thing with returning back to Jellybean if you don't like KitKat. YOU MUST flash the loader.bin from the Jellybean ROM to go back.
If you are wanting the most stable ROM for daily use that EVERYTHING WORKS on, then the Finless ROM is the better choice.
If you want to try the newest, hottest firmware (beta), then KitKat maybe worth the risk, but please don't complain about the missing features...they are already well documented, and must be addressed by Pipo. I don't port other ROM's to Pipo tablets...too many headaches...so I just make my ROM's from official Pipo firmware.
I don't have an M9 Pro tablet at the moment, but on my M6 Pro, U8 and very soon my M7 Pro will be running my KitKat ROM's, because I'm quite happy with the performance and the new look. I don't use GPS, anyway.Randy
kasty-pipo-m9_pro-422-ota_20131209-rooted4
My m9pro is 3days old and it came with JB 4.2.2 and i flashed it with pipo stock 4.4.2 KK rom and it`s still beta for testing purposes only and half cooked and now i am on kasty-pipo-m9_pro-422-ota_20131209-rooted4
but this rom has a small issue! the bottom navigation bar flashes rapidly sometimes it`s a known bug!
other than that it works pretty good!
so would you recommend me to flash the finless 1.5 rom over this kasty rom?
thank you!
Originally posted by rrileypm View PostIt depends on what your definition of "best" is.
I don't have an M9 Pro tablet at the moment, but on my M6 Pro, U8 and very soon my M7 Pro will be running my KitKat ROM's, because I'm quite happy with the performance and the new look. I don't use GPS, anyway.PROUD owner of PiPO M9 Pro
PiPO P9 best tablet ever owned!!!
PiPO Tablet Freak and Flashaholic!
Originally posted by Kenneth View PostMy m9pro is 3days old and it came with JB 4.2.2 and i flashed it with pipo stock 4.4.2 KK rom and it`s still beta for testing purposes only and half cooked and now i am on kasty-pipo-m9_pro-422-ota_20131209-rooted4
thank you!
Now I'm testing 4.2.2 official. But it literally sucks my battery.
About an hour of screen on on each full charge.
Next Sunday, or maybe tomorrow, I'll install Riley's KK.
Originally posted by belier View PostI had kasty ROM installed. I ended bored about having to hard reset it when the tablet went to deep sleep.
Originally posted by Kenneth View Posti suggest that you and or bob post some screenshots of this rom so we can have a taste before flashing
Maybe Bob want to post some screenshots,i won't
Originally posted by ludoke View PostWhat's important to you ,the looks or the fact it's running great with an exellent battery life,that's what most users want,i think.
you are right just asking matePROUD owner of PiPO M9 Pro
Sorry, I don't have an M9 Pro...so I can't do the screen shots.Randy
There are currently 1902 users online. 0 members and 1902 guests.
