ATV520 recovery via rs232
    It seems that my 520 will not boot through sd/usb no matter what, so wanted to try flashing thru usb -> ttl rs232 cable, I have all the files and programs to hand but cannot find a layout of the pins. Ive attached a photo in the hope that someone can guide me. The cable is a prolific 2303HX usb cable.
    Concerning this picture from Prometheus:
    and picture of your device pins should be:
    NC RX GND TX (from left to right)
    If you succeed to unbrick your device, please, be so kind to share exact procedure with us (I have the same problem with different Amlogic device - Bluetimes MX5).
      thanks for the link, I did see this pic earlier and wasnt sure as the board was a different layout. I will of course post any results from.
        NP, dude. Where did you find unlock procedure?
        Also did you try to recover using nand pin shorten procedure?
          Originally posted by dankec View Post
          ... If you succeed to unbrick your device, please, be so kind to share exact procedure with us (I have the same problem with different Amlogic device - Bluetimes MX5).
          Maybe this will help you :
