thanks
hi can you help i am new
Originally posted by madmanuk View Posthi all looks good here,I need help with my arnova 10 g2, I have downloaded a book from amazon and can't read the top line can anyone help please.
thanks
What reader app are you using? Amazon will be Kindle (.mobi) format, if you're not using the official app download it from the Play store and use that. You can also get the application for your PC so I'd try both to see if the problem is the same on both.
Cheers
Cheers
if you are using you tablet out of the box with its own software on it it will not be routed so the above will not work for you, i can't find a way to solve the problem without having root on your device (@bob finlessis there anyway to root the arnova 10g2 without rom install??) if bob says there is do that 1st the retry the above steps if not only way is to install a new rom i would recommend bob's v1.5 rom from this site, NB be aware that if you flash a new rom there is a risk you can brick your tablet please don't flash just because i said so look into doing it first and if you as sure about doing it then go ahead i am sure bob, damo or other of the people here who deal with rom cooking will be happy to help if you want to flash this would give you root access and again follow the above steps to fix kindle
hope this helps
rickyRicky
New here but learning something new everyday
You can get what is called a Simi-root using tools like Gingerbreak. This will give you SU access to the Android OS. But you cannot modify any files in /system without a ROM flash to change that.
The reason is on many tablets /system is a CramFS file system which is read only! So to get full root access and be able to customize the device beyond what the manufacturer allows, you need to flash a ROM.
Originally posted by Finless View PostYou can get what is called a Simi-root using tools like Gingerbreak. This will give you SU access to the Android OS. But you cannot modify any files in /system without a ROM flash to change that.
rickyRicky
No those are system files and require read write to /system so no way... You need to flash a ROM.
root
hi and thanks for all your help but in the end i flashed it with,I don't know lol but i can now hide the toolbar and read kindle books ok with the top line showing,I would have got it to this more if it was mine but the tab don't belong to me,I would have bricked it just to see if i could mend it lol,Anyway keep up the good work and thanks,I prob will be back soon tho.
There are currently 3231 users online. 2 members and 3229 guests.
