Pipo M3 RileyROM 1.2
    This ROM is based on official Pipo firmware dated 1/10/14.
    Auto Install Apps from External SD (see this thread for details)
    As usual this ROM is:
    Rooted
    Debloated
    Init.d Support
    Busybox Support
    English Default
    Working CWM Recovery installed after first boot
    2, 4, 6, 8, or 12gb user app space by changing parameter files (I'm not sure how much NAND is available...so be careful not to choose a file that is larger than your total NAND available...leave about 1gb for the system)
    Boot Animation by Tattman65
    Reboot app by Petrus
    Updated First Time User's Guide (Please read this guide before attempting to install the first time)
    RKBatchTool included in the kit as an alternate way to reboot to flash mode (Switch button)
    Rockchip driver installer app is now included in the kit
    Download
    If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com Donate!!! Your donations keep me updated with the latest tablets to test on.
    Randy
    Sv: Pipo M3 RileyROM 1.2
    Is this for 3g
    From my daycruiser
      It is for both.
      Sent from my SAMSUNG-SGH-I537 using Tapatalk
      Randy
        Ok tanks i Will report back soon tanks again
        From my daycruiser
          Hello The touch is reversed. Same problem whit kernel as 1.1
          I flashed kernel from 1.0 and everything is ok. Do you now ho to contact to get this fixed?
          Regards wikings1
          From my daycruiser
            If the ROM works with the 1.0 kernel...stick with it.
            Randy
              Oki tanks
              From my daycruiser
                Android 4.1.1 query
                Hi I flashed this ROM to an old M3, everything working fine but Android is showing as 4.1.1
                Since rom is dated 2014 was hoping to get 4.2 - is 4.1.1 correct ?
                thanks,
                jamie
                  To my knowledge, Pipo has not released a 4.2.2 firmware for any of their older rk3066 tablets. I'm not sure what the update was in this one.
                  Randy
                    Thanks for the update, I thought that was the case.
                    Pity Pipo dont publish an update log with their roms so we can see what has been updated.
                    Looks like 4.2 on M3 may not happen.
                    cheers,
                    jamie
                      Did you use the kernel included
                      From my daycruiser
                        From my daycruiser
                        Yes I used the 1.2 kernel, noticed your problems with touch reversed but I had no problems.
                        Have also flashed a friends M3 and again working fine.
                          Maybe i try to flash kernel again
                          From my daycruiser
                            Do you have the 3 g modell
                            From my daycruiser
                              From my daycruiser
                              No just WiFi M3
