My 701 C is doing it a lot...and it seems to be getting much much worse. It's gotten to the point where it makes it unusable since I never know whether I'll get 5 minutes, 10, 15 or a full half hour before reboot.
I did experience random reboots at times with the stock Gingerbread ROM. I do recall the tablet randomly rebooting before I ever started doing much but playing a game or two on it. I honestly just ignored it at first. I just assumed the game I was playing wasn't agreeing with the tablet etc. Now that I've had more use on the tablet I'm seeing the reboots are really quite common. They've been much worse since I upgraded to ICS.
It's aggravating as h_ll because I can't figure out what is causing it. At first I thought it was some rouge app I installed...but I've noticed it randomly rebooting after a fresh flash on a brand new stock ROM with NO apps installed other than the ones with the ROM.
It seems to be purely random. Sometimes it will reboot when I'm sitting at the "Home" screen doing nothing. Sometimes it will reboot when I'm doing something like accessing a settings menu, opening an app, browsing etc.
Sometimes it does a sort of half kernel reboot, and sometimes it does the full reboot.
As I type I seem to be stuck in a boot loop. It will sit on the ICS droid logo with the spinning half circles and sit there for a looong time. Then it will typically go black, show the polaroid logo and start the whole loop over again. Pressing the reset button does nothing but restart the boot loop again. As does holding the power button down. It seems the only way I'm going to recover easily now is to reflash because it's stuck in a boot loop for no readily apparent reason.
It did this yesterday as well. In fact yesterday it really wacked out and ended up rebooting itself a few times in a row. When it was done I got some message that my data couldn't be accessed anymore and the tablet would need to be reset. It then wiped itself clean. I'm sure it just corrupted itself by doing something like rebooting itself before it was fully booted off another reboot. (Luckily I don't keep anything on here I give two craps about losing, because it is terribly unstable at this point.)
It seems the more I use it the worse things get. I will do a format and fresh flash of a ROM via livesuit and it will usually spontaneously reboot right from a fresh ROM flash with no apps installed. I've had it reboot in a matter of a minute or two after a ROM flash or sometimes it takes awhile. It's never a matter of if...but when.
I'm 100% confident this is not caused by any app I'm installing since it does it with a stock rom flashed and NO apps installed. Of course installing apps may end up making things worse but I know it's not the initial cause.
Could this be heat related? My tablet gets warm to the touch but it doesn't seem like it would be hot enough to initiate any kind of thermal shutdown.
I'm very green to the world of Android. Can anyone point me to some sort of log I can access and post to help trouble shoot things?
Since this does this on fresh ROM flashes I'm guessing it's something hardware related. Of course I'm out of the 30 day B.L. return window by about 7 days . Since I've flashed a non stock ROM at one point I'm sure I'm out of warranty as well (although I'm not sure they would know). I'm really trying to avoid the urge to buy another one and swap this one with the one in the box and return it.
