USB Ethernet
Originally posted by billgatos View PostHas anyone bought one of this and tested on the RK devices.
Hello,
I have aslo a ethernet USB, but it is not working for me.
This is because the drivers are for a old kernal, it needs to compile to the new kernal.
I don't know how, also never find drivers for it.
If some can do it, than it is fine and it works.
But till now, no new drivers for the new kernals....
I help with 4GD663269M466950W
And you ????
My devices:
Tronsmart T428 real 3188 with Finless A928 and D33 Kernel at 720p
Tronsmart Prometheus won on CNX just now....
Originally posted by Pluto View Posti highly doubt that it will make use of all the ethernet wires, you'd be limited to 10/100 due to USB 2.0.
I just wanna acquire some good usb 2.0 ethernet adapter with real speedI help with 4GD663269M466950W
And you ????
My devices:
Some routers that include USB ports (the new one though) allow the USB to be used as a network interface as well, i know Thomson products can do this, i am not sure if Android would support that though, it took a driver installation for Windows.
What i mean is you clould squeeze the max of usb 2.0 (400mbit), it's gonna take a thorough research though.
Personnally, i use on my tablet, the "Wii Lan Adapter".
It's run correctly"Just ATP"
- MTKZenyT(ools) : Tools to backup, flash, root'n unroot under GNU/Linux
Phone: Xiaomi Redmi 1
Tablets: CDisplay SV1.0.6 (original); PiPo M8HD (under RileyRom 1.9)
USB Ethernet
In case you are using a mini pc without a built-in ethernet port
what you need to buy is an adapter with a specific chipset, look for an adapter with
chipset AX88772B
like this:
http://www.****.com/itm/USB-2-0-to-Lan-Ethernet-Adapter-Cable-AX88772B-for-NEXUS-7-10-Anoroid-4-x-1M-s-/321241770534?pt=LH_DefaultDomain_0&hash=item4acb80 6a26
or this:
http://www.****.com/itm/USB-2-0-to-L...item3a870c8988
there are two more versions AX88772 and AX88772A but it think the B is the latest version.
USB 3 / 1000 MBPS will never work, waste of money to try !!!
make sure that what you buy specifically say "AX88772B" in the title of the item....
enjoy....
Thank Zeevg for your info. That 's really what i was looking for.
Best regards to all.
Originally posted by zeevg View PostIn case you are using a mini pc without a built-in ethernet port
chipset AX88772B
like this:
or this:
enjoy....I help with 4GD663269M466950W
And you ????
My devices:
Originally posted by billgatos View PostThank Zeevg for your info. That 's really what i was looking for.
hope I saved you from having two or three of the wrong one's lying around without use and a couple of cancellations and refunds through **** in the process of research for this info, like i have now
just receive the new usb adapter
i bought this one http://www.****.co.uk/itm/3607811768...84.m1439.l2649 thanks for indicating me.
So i tested it on my t428 with kitkat and it copied a mkv of 1.0 gig size and the speed achieved was something like 8Mb/s not really bad. Also i found that i have one of those usb hub not powered and it doesn't juice the adapter as i think.So i now i have a decent ubs ethernet adapter but not a decent usb hub.
Google will help definitely sure.I help with 4GD663269M466950W
And you ????
My devices:
Re: USB Ethernet
I bought a UtechSmart usb 2.0 10/100 adapter with the "A" variant chip. Got it for $15 CAD on Amazon. No more video buffering. I love it!
Here is a link to info on the AX88772 A and B network chips by Asix
There is more to differ them than a series generation. They are similiar, but not entirely identical.
Sent from my SGH-I337M using TapatalkPlease post your h/w & s/w as signature to help community with troubleshooting problems.
Mk802IV / AP6210 (RK3188) - SMIC717394 809III 1080p 4.4 (v2) base & default kernel w/ 4gb parameter.
uTechsmart (Asix AX88772 chip) USB Ethernet Adapter
iLuv iAD517 2.1A USB PS + Asus AD83531 2.0A USB PS
Motorola 89451N BT KB + Logitech K400r 2.4GHz KB
There are currently 2671 users online. 0 members and 2671 guests.
