i tested tronsmart a928 kit kat beta rom on t428 !!!
    i tested,i am using this rom with kernel of strauzo, is very good, the performance is good too no reboots, wifi and BT are working flawless congratulations to strauzo to the kernel..
    tronsmart t428// rom: tronsmart a928 kitkat 4.4 beta.// kernel: t428_kernel_1080p_strauzo
    Do you have a link to the a928 ROM? Any installation guide?
      http://www.freaktab.com/showthread.php?9604-T428-(AP6330-Wireless-chipset)-Kernels-for-KitKat-4-4-2-beta&p=133357&viewfull=1#post133357
      another KK rom is here: http://www.mediafire.com/?7t8bjt0g6606tf1
      password for unpack: www.geekbuying.com
        Re: i tested tronsmart a928 kit kat beta rom on t428 !!!
        Awesome. Thanks!
        Sent from my SCH-I605 using Tapatalk
          rom links and tutorial
          these links are wrong the rom, the rom I used is the official trosmart
          here is the link:
          obs. you have to dismember the rom with the app RUNME.BAT to get the system.img file
          rom: http://www.mediafire.com/download/we....4+beta0.1.rar
          app: https://www.dropbox.com/s/0xywat5m98...G_Mod_Tool.zip
          kernel 1080p : http://d-h.st/6q2
          tutorial in images: https://www.dropbox.com/s/spfn5rz1w5c27yk/tutorial.zip
          thanks to strauzo to the kernel
            How is a 4.1.2 kernel running on a 4.4 ROM? I thought there were some major changes even between 4.1.x and 4.3 that required separate kernels, let alone 4.4. It maybe just for my phone running proprietary stuff, but I thought each major revision of Android required a new kernel.
            Isn't the Kernel you said you are using a modified 4.1.2 kernel that has OC to cpu/gpu/memory?
            Im not saying its not working, or I dont believe you. Im just curious. It makes me think that maybe its not a true 4.4 ROM. Than again, Im not a developer.
            TV Stick: MK808 // Tronsmart T428
            ROM: Finless 1.7c w/Pimp My Rom // Nexus SDK2 Multi-Window v1.2
            CPU: @1.6GHz OnDemand Governor NOOP I/O Scheduler
            Recovery: ClockworkMod
            Kernel: Omegamoon // 1080p OC kernel 720ddr 1.9cpu
            Phone: Samsung Galaxy Note II
            ROM: Whompasaurus v4.2
            Kernel: Persus
              it's all very simple! I just separated the system.img from rom and installed the kernel strauzo with parameters and recovery and other files from the rom finless kat kit for T428, this was not a problem for me and is running flawless here!
              this rom I posted the link is the manufacturer itself: TRONSMART
              I just did test installing it on my T428. and because the kernel can use wifi and bluetooth without problems
              rom link and info:http://blog.geekbuying.com/index.php.../#.Uuha1PlTuUl
              ps: I'm not a developer, just curious and seeking to become developer!
