Hulu Plus Crashes X7 Quickshot V2
    Hey guys, I recently installed the Quickshot V2 Rom and now when I click on a video in the Hulu Plus app it will immediately freeze the box and power it down. Only way to get it to reboot is to pull the power cord, then plug it back in and reboot.
    I was running the stock 006 firmware before and the Hulu Plus app worked perfectly.
    Just wondering if anyone has been having a similar issue?
    Watch Espn
    A few other apps crash the same way. Anyone know why HBOgo is seriously lacking picture quality and full screen?
      Check to see if you have ad blocking app installed.
      Currently Inactive on Freaktab.com
      I use: MK903V | MELE F10 Deluxe | Roku 3600R
      RIP: MK808b | MK809III | PIPO M9 Pro
        Adaway was installed but I disabled, then uninstalled it and rebooted the device. No change, Hulu stil crashes it.
          Bump, any ideas here guys? I love the rom but will be uninstalling if I cant get something this simple to work. I use Hulu a lot.
            Hi, i'm looking for a fix to some apps not showing video and i wonder if this is the same case.
            Try to activate overlay with the quickflasher patch and run hulu again.
            There are 10 types of people in the world: Those who understand binary, and those who don't...
            If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
              How do I activate overlay, and with what qf patch?
                The one mentioned in the first few posts for the ROM... you use quickflasher to install it, then reboot
                  Just flashed the overlay patch and no change. Hulu still crashes it
                    Re: Hulu Plus Crashes X7 Quickshot V2
                    Can you try with old versions of the apk? Is only a idea, because here in Spain we cant use this app.
                    leolas.
                    My devices:
                    Gearbest.com)
                      this version of hulu pus works good for me on quickshot rom
                        Thanks a lot!!!
                        leolas.
                        My devices:
                        Gearbest.com)
                          I found a workaround that involves an xbmc add-on and hulu doesn't require an account but I keep mine for other media players. Props to User Bueno for the suggestion.
                            This apk appears to be working without a hitch for me so far. Thanks a lot
