I have a TV01 and tried to overclock via kernel patching, but I failed.
The reason seems to be a locked down rk3188T chipset. As a result you can patch the kernel, but it has no effect, because the cpu is locked at 1402 Mhz.
Here in this thread, you find a discussion about the topic.
So far there is no way to unlock the Model T's.Maybe they are locked down, because they are of unstable quality, if you would use a higher clock.
I don't know, if all cs968 and clones have the Model T inside.
If someone wants to test it, I can help.
JDfense
