Can't flash TV01 (not recognized)
Ok, something went wrong while flashing my TV01 and I'm left with a device that I can't flash. I've tried a lot of different senarios to flash but none seem to recognize it. Does anyone know about the shorting of pins D5 and D6? If so can you explain it to me so I can get up and running again. Thanks in advance.Tags: None
Originally posted by brick0044 View PostOk, something went wrong while flashing my TV01 and I'm left with a device that I can't flash. I've tried a lot of different senarios to flash but none seem to recognize it. Does anyone know about the shorting of pins D5 and D6? If so can you explain it to me so I can get up and running again. Thanks in advance.
Do you know which chip is the NAND chip? I found this link http://www.freaktab.com/showthread.p...D-on-the-MK808 and will follow steps in here when I figure out which chip is the NAND chip and figure out which is the D5 and D6 pins. Hope I can find more on which chip it is.
Originally posted by brick0044 View PostDo you know which chip is the NAND chip? I found this link http://www.freaktab.com/showthread.p...D-on-the-MK808 and will follow steps in here when I figure out which chip is the NAND chip and figure out which is the D5 and D6 pins. Hope I can find more on which chip it is.
Originally posted by Tech1 View PostNo I don't ... You are out of my league, you are now in the twilight zone ... See Finless the Administrator here of this website ...Please consider making a Donation to freakTab
Originally posted by blinkone View PostThis is your nand chip the dot on the chip is where pin 1 is,its either pin 6&7 you short or 7&8 or it could even be pin 8&9 it seems to change device to device
Originally posted by brick0044 View PostYES, back in business!!!!! Now back to the fun. It was pins 8&9 then went into Maskrom mode then was able to flash in RKbatch tool.Please consider making a Donation to freakTab
Originally posted by brick0044 View PostI went back to 8188_GT-19300_htc_t018_public_Mtk_20140127. Everything works except keep getting script errors in Beyond XBMC Beta 2.9 (GT-I9300). But that is small beans compared to last nights issues.
There are currently 2039 users online. 3 members and 2036 guests.
