This worked at treat and i got the Android market and was working well.
After some forum reading i found the 1.4a version of the ROM, so i then flashed the ROM with this version. (I know over eager)
And initial it seems that all was working. Then i found a couple of issues.
1) The battery would not charge, it seemed to be stuck at 15%. The Power light is green all the time.
2) Booting with out power lead plugged in the Battery showed about 60%
3) When shutting down with the power lead attached it shuts down but the screen does not go black it goes while as if power is attached and so it bright.
Would it be better to re-flash back to the 1.4 version, but saying the i see there is a 1.5 out, should i use that.
Thank you in advance
Simon
