Streaming from HDHomerun tuner
I just purchased the new HDHomerun networked TV tuner and was hoping to stream TV broadcast to my TV through my android box. I have a T428 and TV01 (cs968) and was hoping I could stream my TV signal to these boxes for decoding and pass the signal to the TV. The new HDHomerun transcodes the signal to H.264 before streaming the signal. I thought these rockchip 3188 devices would be able to transcode these signals and pass the signal to my tv. The sd signal works great, no lag or stutter or anything, however the hd channels, 720p or 1080i, are all blotchy and stutters badly. Does these 3188 boxes have the guts to transcode H.264, and if so what do I need to do to my android boxes to make that happen. What about an android box with either an amlogic or allwinner processor, would they work for my situation. I had a CS918S (allwinner a31) in my hands, but it was for my daughter. I was not able to test to see if that box would have decoded the H.264 signal without buffering or stuttering. Any thoughts? My objective it to use the android box for all my audio video needs, and eliminate my OTA DVR, my boxee box and other media streaming devices. One device does it all. Is that possible?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68 -
YOU'RE SOL with android & 3188
A friend of mine just purchased the HDHomerune Prime with (Xfinity) cable service and he tried several android devices including the SG3 with same results at 720P or 1080i channels you get micro stutter. I rigged her 2 HTPC's with 2 Intel Nucs (Celeron & i3) running a lite version of Windows 7 with Windows Media Center as the media center running everything. ZERO stutter playing anything and I mean ANYTHING. I also tried some 4k vids and they played smooth with i3, the celeron just doesn't have enough horse power for that.
I ran the Nuc with Linux, XBMCBuntu, Openlec and Mountain Lion OS. & it runs like a champ. That type of testing is completely out of the question with these crappy sticks. I have given up on these crappy chinese build android devices because they completely unreliable for video playing. Even the new quad core amlogic has problems playing "true 1080P" vids. Anytime you run android, you are limited to 720P vids and even those with high bitrates won't play properly. Electronic garbage!!!
Originally posted by xlux View PostA friend of mine just purchased the HDHomerune Prime with (Xfinity) cable service and he tried several android devices including the SG3 with same results at 720P or 1080i channels you get micro stutter. I rigged her 2 HTPC's with 2 Intel Nucs (Celeron & i3) running a lite version of Windows 7 with Windows Media Center as the media center running everything. ZERO stutter playing anything and I mean ANYTHING. I also tried some 4k vids and they played smooth with i3, the celeron just doesn't have enough horse power for that.
I ran the Nuc with Linux, XBMCBuntu, Openlec and Mountain Lion OS. & it runs like a champ. That type of testing is completely out of the question with these crappy sticks. I have given up on these crappy chinese build android devices because they completely unreliable for video playing. Even the new quad core amlogic has problems playing "true 1080P" vids. Anytime you run android, you are limited to 720P vids and even those with high bitrates won't play properly. Electronic garbage!!!MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Her husband bought the Onda V975M tab when it came out. Most channels had a small degree of micro stutter here and there but you had to really be looking for it (which I was) otherwise I was really noticeable on some of the 720P channels.
If you really want hassle free viewing then dump Android & go with a Mac Mini (used) or a Intel Nuc (cheapest) if you don't need 3D or gaming. If you don't care about power consumption, then get one of your old pcs's & convert it to a HTPC or build one. Trust me whatever money you're saving with these cheap sticks/set-top boxes, you will pay with frustration at the end. It's not as I haven't giving Android a fair chance on the contrary, I have tested many Android devices including SG3, SG4, Note2 & Note3. All have limitations & shortcomings on simple tasks like streaming 720P video.
Originally posted by xlux View PostHer husband bought the Onda V975M tab when it came out. Most channels had a small degree of micro stutter here and there but you had to really be looking for it (which I was) otherwise I was really noticeable on some of the 720P channels.
If you really want hassle free viewing then dump Android & go with a Mac Mini (used) or a Intel Nuc (cheapest) if you don't need 3D or gaming. If you don't care about power consumption, then get one of your old pcs's & convert it to a HTPC or build one. Trust me whatever money you're saving with these cheap sticks/set-top boxes, you will pay with frustration at the end. It's not as I haven't giving Android a fair chance on the contrary, I have tested many Android devices including SG3, SG4, Note2 & Note3. All have limitations & shortcomings on simple tasks like streaming 720P video.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
We both think alike & that's why we both started testing these Android devices. However, fanless doesn't mean a fan is not needed. My 3rd Android device (Matricom MX2) gets HOT & I mean HOT!! I had to modify the case to avoid getting fried. I build my own HTPC a while ago from an old ITX board I had laying around. I bought a small factor case & an a low power psu. You couldn't hear the fan unless you got in all fours & put your ears behind the case. It worked well except for the power consumption. You will see it in your monthly bill.
The other problem with these Android devices is the app discrepancies like Netflix, HBO Go, Xfinity apps,,, etc. You can have one of there other. You either get the XBMC working great but the apps will flop. I agree with you as far as just having an inexpensive fanless HTPC until you come to the realization of the limitations of Android. I saw my neighbor's HTPC (Intel NUC) setup last year & I was impressed! He has the i5 & it is flawless. That's where I got the idea for my friend. I mean this thing packs lots of computer horsepower for its size factor. You can't hear the fan unless you put your ear close to the case outlet. This thing can run the next 3 builds of Windows easily so it will be around in your inventory.
Here where Android lacks bigtime, nobody is going to be running Android 2.2 on purpose. As a matter of fact ICS will be obsolete soon. I still run WinXP as my do it all troubleshooter on an old laptop of mine. That's what I use to flash all my Android devices. Android is simple but lacks refinement.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Originally posted by xlux View PostWe both think alike & that's why we both started testing these Android devices. However, fanless doesn't mean a fan is not needed. My 3rd Android device (Matricom MX2) gets HOT & I mean HOT!! I had to modify the case to avoid getting fried. I build my own HTPC a while ago from an old ITX board I had laying around. I bought a small factor case & an a low power psu. You couldn't hear the fan unless you got in all fours & put your ears behind the case. It worked well except for the power consumption. You will see it in your monthly bill.
Sent from my SAMSUNG-SGH-I747 using TapatalkMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I love testing too but after a while, these Android devices start to add up. I'm contemplating getting an Intel NUC & calling it day. I already setup 2 for a friend so I know their capabilities. The question is whether to go i3 or i5?
For me Android is too limited even at bare minimums. The HBO GO app has never worked correctly & Netflix still lacks quantity.
BTW: it is not wifi that makes the stutter but the lack of proper hardware support.
hi, i have 2 hdhomerun dual gen 3 hdhr3-us.
i think i figured out how to help. i use my minic neo x7 at times just figured out tonite how to sop the stuttering, i went into the settings in mx player and changed it from software decoding to hardware decoding, also deinterlace is on. and it ran fine , no pixelation and no streaking.
hope this helps.
Originally posted by xlux View PostI love testing too but after a while, these TV droid devices start to add up. I'm contemplating getting an Intel NUC & calling it day. I already setup 2 for a friend so I know their capabilities. The question is whether to go i3 or i5?
Originally posted by clarkss12 View PostAfter tweaking and fine tuning my hdhomerun duo and my android tv box, everything is running great. My HD channels are running flawlessly in xbmc. The picture and audio quality are fantastic. The audio is 5.1 Dolby digital. You were correct about wireless NOT being the problem of poor picture quality. I tested my setup with my wireless G and everything played perfectly. I can say that my $85 box now will compete with a $350 mini htpc.
Originally posted by kblgy View Postis it possible to let us know what you did? settings?
Originally posted by clarkss12 View PostI have the new Hdhomerun Plus which encodes the signal to H.264, also uses Upnp. Here are some pics of my tuner set up.
[ATTACH=CONFIG]5276[/ATTACH][ATTACH=CONFIG]5277[/ATTACH][ATTACH=CONFIG]5278[/ATTACH][ATTACH=CONFIG]5279[/ATTACH][ATTACH=CONFIG]5280[/ATTACH]
Originally posted by clarkss12 View PostI can say that my $85 box now will compete with a $350 mini htpc
I can run whatever OS I desire or run 2 OS's if I decide to test. I have full 1080P, full 3D, 30 day guide and it will be competitive for the next 5 years. Ever heard of gingerbread, yeah I don't think you would wanna run that & that's what will happen to JB after a few months. Like I said, NOT EVEN CLOSE...
Then again, android was never meant to replace a PC nor windows for that matter. When it comes to price, it has PC in the dust; no doubt!! You pay for what you get & if all you want is to just do bare minimums; then android is a good choice...
Originally posted by xlux View PostKUDOS!! bro, good job...
Nahhh!! NOT EVEN CLOSE. Your $85 box can will only run android & in a year it will be obsolete. You can't really play full blown 1080P, You can't really see 3D movies, you don't really have a full guide, XBMC is still not be fully supported on android and it could just die for no apparent reason at any time???
Then again, android was never meant to replace a PC nor windows for that matter. When it comes to price, it has PC in the dust; no doubt!! You pay for what you get & if all you want is to just do bare minimums; then android is a good choice...MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 2716 users online. 0 members and 2716 guests.
