I am not professional, please don't beat))) Better help me!
I have Ditter V21. I added big radiator, because it was overheating.
Now it works ok. I don't have any poor emotions with it. It works better than my Imito MX2, because WIFI is much better. One problem is what "screen percent" comes to default after each reboot, so picture has black frame over the border. After reboot, the slider of "screen percent" is in choosen by me the rightmost position. But in fact there is a frame around the screen like the default settings. Choosen position that displayed does not correspond real settings. But I fixed this issue in my LCD TV settings. I don't know, is there interpolation. Picture and fonts look clear, not blurr.
Second problem, what sometimes, if you do many actions, interface can freeze for 2 seconds. If you don't want to wait 2 seconds, you can immediately press HOME button, and it immediately stops freeze. This issue is not so big problem, as I feel. I don't find that problem on clear system after hard reset. Maybe one of post installed apps makes that.
I tried NFS Most Wanted. It shows x1.5 more FPS than Imito(rk3066). That's cool.
I don't try to see 3D or Full HD video, because i don't need this. I always use only mkv(h.264) 2-3Gb. Because it downloads fast. And usually I use it for watch TV over internet. HD channels look OK.
It has two hardware buttons on board. One is firmware update mode. Second - is hard reset.
I can't find any firmware files in internet.
I got root with update for Onda tablet(A31).
I saved firmware's partition's images via terminal emulator. Is it right action?
It wrote, what it has Android 4.2.2 kernel version 3.3.0. How can I check, is it true?
I want to add init.d support. How can I make this?
I want to change kernel to 1080. Is it real?
Has any idea, how to fix issue with "screen persent"?
If you have any questions, feel free to ask.
On other forum, one man wrote, what build.prop is like MK823. Is firmware compatible?
build.prop.txt
