Monitoring Minix Neo X7 CPU Temperature?
Re: Monitoring Minix Neo X7 CPU Temperature?
Originally posted by Lauris6rape View PostI want to monitor CPU's temp for a while, because of OCed kernel. I tried quite many apps but no luck, is it even possible to monitor CPU temp in this device? Thanks in advance
leolas.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostActually not.
leolas.
Yep, some of the apps do not detect neither CPU temp sensor nor GPU temp sensor... Well I have a black cooling pad, which is from 4pcs of desktop computer cooling fans. I am at 1080p 1708CPU 798GPU 720RAM and device never gets hot, not even warm. It would be nice experiment to make some additional ventilation holes in the device and go full OCjust to check stability.
I have 1800-798-720 on my x7 mini. It doesn't get warm doing normal things like installing apps, playing video, and browsing the web.
I guess if you were a gamer it might get warm, but it's fine so far. No mods at all hardware wise.1.8Ghz Celeron 1037u based OpenELEC HTPC - Sadly PWNS all Androids everywhere
"In a world that exists without walls and fences, who needs Windows and Gates?"
Originally posted by sketchman View PostI have 1800-798-720 on my x7 mini. It doesn't get warm doing normal things like installing apps, playing video, and browsing the web.
I guess if you were a gamer it might get warm, but it's fine so far. No mods at all hardware wise.i get 3439 at 3D graphics on Antutu Benchmark with my current kernel, have you different result or actual performance increase comparing to 1.7ghz?
Originally posted by Lauris6rape View PostI like gamesi get 3439 at 3D graphics on Antutu Benchmark with my current kernel, have you different result or actual performance increase comparing to 1.7ghz?
Originally posted by sketchman View PostHmm. Not sure. I don't do games really. I got 21192 total in Antutu. Didn't pay attention to the 3D part, because I don't really use it. If i can remember I'll run it again and post it for you.
It would be great, these Antutu 3D points are not really 100% true, but it says something. If talking about total score I get 20250 usually. What i really care how device performs while playing games for lets say 3-4 hours. Does it run smooth and fast for all the time or does it run smooth at the begining and then gets hot and unstable. If you can run a game smooth for 5 minutes it says nothing. Or if ur system is stable and smooth at MAX OC, but when you try to really stress it - it fails... I dont need short time performance, I need good performance for stressful situationsI would go for 720p instead of 1080p even to get long staying performance. So yeah, please check your system and share the info, it will help for me, if you have time
There are currently 2561 users online. 0 members and 2561 guests.
