Volktablet (Trekstor) 10.1" RileyROM 1.0
If you have already read some about making kernels...you are way ahead of me. I'm not a kernel guy.Randy
On post #56, there is a download link to the stock files....just flash those files in place of the ones from the custom ROM, and you should be back to stock.
I can't test the link from my work PC, so I hope it's still available...otherwise you may have to contact the poster of that post. I'm afraid I can't find my copy of the stock firmware in my current archives.Randy
Thank you so much
Originally posted by rrileypm View PostOn post #56, there is a download link to the stock files....just flash those files in place of the ones from the custom ROM, and you should be back to stock.
I do have some issues when flash Trekstor tablet ST10416 1A, I followed rrileypm instruction, but flash finished with error `download file failed` and `run failed`, here`s screenshot!
now I`m stuck, tablet reboot to recovery only
any help would be nice!You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
The main reason for that error is a bad USB connection.
Try a different cable...you should use the one that came with the tablet.
Try a different USB port on your PC...don't use a USB 3.0 port...only 2.0 is compatible.Randy
Originally posted by Dominiktk View PostHi Randy
Thanks a lot for that Firmware. It doesn´t work with the new parameter. I think its because of the emulated SD-Card. This is an added extra from factory Firmware. Its bad i dont have the old firmware before the latest update. That is the base you used for your Rom. With that Firmware the parameters would work I think. With the original parameter your Firmware is working. But there a some things which aren´t clear to me. The stock home launcher draws the Bild apps on home screen. Normally that shouldn´t happen because the apps aren´t in /system/app. But its no problem to delete them manually. The Sixaxis app is working now. I dont know why but I´m happy that it is working know. I have a question: Isn´t is ok to delete the exchange app? Or the Talk app? Any problems with the Firmware if I´m going to delete them? Ok enough at first post. My tests are not finished. I´ll give more feedback when I got the time to test all features. Maybe i´m going to open up a paypal account because i see no other way to support your work. And I think you should get something for your work. I´m not rich but I want to support you.
Best wishes so far
Dominiktk
[QUOTE = rrileypm; n215607] Вот ссылка на первое ПЗУ, которое я сделал с исходным файлом параметров.
Вы можете извлечь файл параметров из этого набора и зажечь новый ПЗУ этим параметром :
[URL] http://www.freak-tab.de/rrileypm/VolkTablet_ROMKit.zip [/ URL]
Пожалуйста, дайте мне знать, как это работает. [/ QUOTE]
Здравствуйте, как мне загрузить эту прошивка? Код ошибки 403 запрещено написано!
Вы может мне на diablovoprekitolik@gmail.com прошивка сможете послать!буду Вам очень признателен!так как у меня нет компьютера и ноутбука хотел пролить планшет через карту памяти в формате zip
Originally posted by Diablo View Post[QUOTE = rrileypm; n215607] Вот ссылка на первое ПЗУ, которое я сделал с исходным файлом параметров.
There are currently 1534 users online. 0 members and 1534 guests.
