Nextbook YFG07 (2013 walmart) possible wifi fix
Finally fixed
thank you Madscientist687. I spent two hours trying to find a fix for the wifi issue. running smooth
Originally posted by pnut180 View Postthank you Madscientist687. I spent two hours trying to find a fix for the wifi issue. running smooth
Thank you!
Hey, Madscientist687, THANK YOU!
After flashing, everything I've tried is working well.
I booted into shaunmt's Modified Stock 3e Recovery (uImage_Recovery in root of SD card),
- factory reset and wiped cache,
- flashed your yfg07-signed.zip (file NOT un-zipped),
- rebooted,
- flashed Kyser_Root-signed.zip (file also NOT un-zipped)
>>>===> all worked great--wifi, camera, rotation, etc.!
My granddaughter thanks you and I thank you!
(I'm also looking forward to your ROM from dump guide)
HOLY CRAP!!!
WOW. I cannot believe this. I've got an AMLogic Nextbook with a serial of YFG09xxxxx and your fix WORKED! I can't believe it. I've been waiting for ShaunMT's fix for months and stumbled on this thread earlier today and just tried it tonight thinking it wasn't going to work since my serial number was different but I thought, "really, what's there to lose at this point?" and I can't believe it! YOU DID IT! Thank you SO VERY, VERY much!
Anyone with a tablet serial number of YFG09xxxxx thinking this won't work, it will! I don't know if ShaunMT's CWM project will ever be completed at this point, and if it's not, at least us users of this tablet have some hope of at least getting it back to running a stock ROM. Thank you so much again!!!
Originally posted by TJBilyk View PostWOW. I cannot believe this. I've got an AMLogic Nextbook with a serial of YFG09xxxxx and your fix WORKED! I can't believe it. I've been waiting for ShaunMT's fix for months and stumbled on this thread earlier today and just tried it tonight thinking it wasn't going to work since my serial number was different but I thought, "really, what's there to lose at this point?" and I can't believe it! YOU DID IT! Thank you SO VERY, VERY much!
Originally posted by roadkill View Postwhat was the fix?
next7p12 YFG0713189064 wifi works
just did upgrade with yur image fixed the wifi. I have 3 of these 2 of them show only bertical streaks on the display. I have located the serial port connector on these units. They have 3 volt level async signals at 115200 baud 8n1. I see boot messages when I power up. I will try your rom image on these later and see if it fixes the display.
There are currently 2164 users online. 1 members and 2163 guests.
