UPDATED CR11S-CS968 GT-Ixxx 2MP/5MP 1080p IMaxx Multi-Media Super ROM (ShowBox ) 4K like Video Playback (BeYond XBMC READY)
    MULTI-MEDIA SUPER ROM, IMAXX QUALITY WITH SHOWBOX BUILT IN BEYOND XBMC READY
    Their is a NEW "VideoMix-2 App" just released, that can be found in the right hand column in the bottom blue link download section HERE https://plus.google.com/communities/...artnerid=gplp0 .....
    *UPDATED! You can now get the 2MP NEW CR11S-CS968 1080p IMaxx Multi-Media Super ROM (UPDATED LCD/DPI To 240), Built IN (ShowBox ) 4K like Video Playback, "Beyond XBMC READY ... Get the download HERE
    *UPDATED! You can now get The 5MP NEW CR11S-CS968 1080p IMaxx Multi-Media Super ROM (UPDATED LCD/DPI To 240), Built IN (ShowBox ) 4K like Video Playback, "Beyond XBMC READY Download HERE
    Use this "Beyond XBMC" Version ONLY http://www.androidfilehost.com/?fid=23329332407567645 ...
    The above 1080p ROM build is a converted 720p ROM to a 1080p ROM build, giving you a 4k like video playback higher enhanced picture pixel crystal clear video resolution quality ...
    No other CR11S/CS968 custom ROM or original manufacturer ROM build has this added video sharpness ... Another thing you should see is increase UI movement speed, very fast, even with a lot of apps on your device ...! This ROM build is truly unique, you will love this one ...!
    "BeYond XBMC Update Again To V3.1
    The "Beyond XBMC" has been update again to v3.1, you can get the latest release for all of my GT-19300 (Spoofed GXXX) ROM builds HERE http://www.androidfilehost.com/?fid=23329332407567645 ...
    "Beyond XBMX" NEW thread is HERE http://www.freaktab.com/showthread.p...d-XBMC-(Beta-3) ....
    *PLEASE NOTE: To make the icons larger, set the icons to 240 ONLY using the Built IN "texdroider_dpi" App and reboot ....
    *PLEASE NOTE: This ROM Build also has a built IN "Cache Cleaner" App, go to "Setting", check mark ALL THE BLOCKS ... Set the "Auto Clear Interval" to one (1) Hour ... This Setting will auto clean your Android TV box every hour ... Also set your "Language" ....!
    *PLEASE NOTE: If you want more popular XBMC "JUST UPDATED" (Channels) add-ons zip files go HERE https://plus.google.com/communities/...artnerid=gplp0 ... The add-ons zip files download is located in the right column bottom blue links section ...
    Based Rom
    Can you share with us wht the base for this rom?
    I'm testing it now...
    Or share some more features?
        Based Rom Request
        Is better use CS968 Exclusive MODDED ROM EQS-v2.0M 1080p as a based ROM.
        Have many features compared with this based V1.1
          Best and latest Rom CR11s / Beyond XBMC configurations 1080p
          What is the best and latest Rom for CR11s? The CR11S-CS968 GT-Ixxx 1080p IMaxx Multi-Media Super ROM or ROM EQS-v2.0M 1080p?
          Which has better compatibility with XBMC? I tried Beyond XBMC, but is not able to play 1080p, tried with a WEB DL 1080p but just played with a External Player (MX Player) ...
          Beyond XBMC need some configuration to play 1080p?
          Thanks,
            For further improvements we will be greatful if the libmedia hack or 5.1 passthrough is added. I also noticed the Addons results open in a slightly smaller window so we only see a list of 4 or 5 items on screen. I feel it can be a bit bigger. But overall a very good start and a promising xbmc platform.
              Originally posted by carlos_db View Post
              Thanks,
              What, that's what it's made for 1080p ...! Tell me the ROM you are using and I can tell you what's wrong ...
                The rom i'm using is CR11S-CS968 (8188 Wifi Works) TV01, 1080p GT-19300 (G3 Spoofed) 2MP/5MP 6210 (Built IN NEW Video Mix App).
                  Test this version of "Beyond XBMC" found HERE
                  http://www.androidfilehost.com/?fid=23329332407567645 .... Uninstall the current version "Beyond XBMC, before install the new version ... After you install it, do a soft reset on your TV box ...
                    Thanks for your help. Before testing the XBMC you recommended, I was thinking about changing ROM. CR11S-CS968 GT-Ixxx 1080p IMaxx Multi-Media Super ROM or ROM EQS-v2.0M 1080p?
                      Yes, "Beyond XBMC" will work with ROM EQS-v2.0M 1080p ...! Please Note: You will not have the same high video resolution quality as the above ROM build ..
                        Thanks for the advise. I'll test the above ROM build and Beyond XBMC, later give you feedback..
                          5MP Version Download
                          *Get The 5MP NEW CR11S-CS968 1080p IMaxx Multi-Media Super ROM, Built IN (ShowBox ) 4K like Video Playback, "Beyond XBMC READY Download HERE
                          http://www.sendspace.com/file/804cjc ...
                            You can now get the NEW CR11S-CS968 1080p IMaxx Multi-Media Super ROM, Built IN (ShowBox ) 4K like Video Playback, "Beyond XBMC READY ... Get the download HERE http://www.sendspace.com/file/tso6k9 ...
                            Is this Rom for devises with Mediatek wifi module?
                              Are they wifi 6210, RK3188 devices ...
