HELP!!! - MK808B, xbmc doesn't open up. Closes when click on it
I have 2 MK808B sticks. One of them is running xbmc fine. With the other stick xbmc runs fine when its first installed. However whenever i install an app from google play store or do any changes in android setting to the stick xbmc won't run. When you click on it it closes. When I clear the cache for xbmc in settings. It will launch up and run fine. I don't have this issue with any other apps on the stick or on the other stick. Both stick purchased from same business and are orginal MK808B not fakes. Any help or suggestions to what I can do would be great thanks -
Originally posted by cwilliam83 View PostI have 2 MK808B sticks. One of them is running xbmc fine. With the other stick xbmc runs fine when its first installed. However whenever i install an app from google play store or do any changes in android setting to the stick xbmc won't run. When you click on it it closes. When I clear the cache for xbmc in settings. It will launch up and run fine. I don't have this issue with any other apps on the stick or on the other stick. Both stick purchased from same business and are orginal MK808B not fakes. Any help or suggestions to what I can do would be great thanks
Hello I got it working. I put the minix hybryd firmware on my device. I tried using finless but it didn't work either.
http://www.freaktab.com/showthread.php?5069-MK808-MK808B-MINIX-Hybryd-FW-V2-2-4-!NEW!%2822-05-2013%29
Originally posted by nimo View PostIn most case it is a cache issue, a clear cache can help but only do it as a last resort as it will erase your addons and what else you had setup..
Or you could just use a backup of the xbmc user folder
By taking out the sdcard......
Seriously, try it. Xbmc is looking for the path, and your Android is saying there are two paths with the same name, something to do with the /mnt. Anyway, I'm not going to pretend i know what I'm taking about, but it worked for me.
There are currently 5960 users online. 2 members and 5958 guests.
