also the only reason i need to flash it ,is bcos some google play games have a flickering screen, is this a common reason to flash, bcos it seems to run well, otherwise,
root before flash?
root before flash?
hi, ive got a new u30hgt 2 , and im trying to understand what i need to do to get it flashed, do i need to root it first?, i need a noob guide
also the only reason i need to flash it ,is bcos some google play games have a flickering screen, is this a common reason to flash, bcos it seems to run well, otherwise,Tags: None
This guide is for Pipo tablets, but the information is the same for all Rockchip tablets:
Randy
Originally posted by rrileypm View PostThis guide is for Pipo tablets, but the information is the same for all Rockchip tablets:
http://www.freaktab.com/showthread.p...for-RileyROM-s
thansk and question
thanks for this guide - very clear
i have a couple of questions as i slowly build confidence to just go for a ROM flash....
tablet - Cube U30gt2 MH, RK3188, stock 4.2.2 v1.0028112013
before i try a new ROM i'm trying to back up current stock firmware...
trying to install CWM recovery - i flashed just the CWM recovery img for my U30gt2 using the RKAndroid Tool 1.37. seemed to go fine but i was expecting the recovery img to force a dumped img "backup" file of current system ROM so that i could use it as a backup to return to stock ROM...
nothing happened on reboot...
i only flashed the provided recovery img - should I also have flashed the misc img too so as to enable the next boot to go to recovery and initiate the CWM img dump.... ?
if yes, will the new misc img file be re-written after first boot as per your guide ?
should i erase IBD prior to flashing just recovery img or flashing recovery & misc img files...
many thanks!
There are currently 1220 users online. 0 members and 1220 guests.
