1. I downloaded the CX-919 4.4.2 Finless 2.0 Beta files.
2. Connected my J22 device to my windows 7 PC with the OTG usb cable.
3. PC recognized the device and I installed the drivers with no problems.
4. Opened the ROM Flash Tool 137 in the folder and it displayed at the bottom "Found RKAndroid Rock USB".
5. I then clicked the button "reboot to flash mode". It failed and did nothing. So as per the instructions in the readme file I ran RKBatchTool.exe.
6. Clicked on the "Switch" button and it rebooted the device into flash mode.
7. Next went back to Finless ROM Flash tool and clicked on "Erase NAND (IDB)". So far so good, it erased wit no problems.
8. Left all the options in the window as default, then clicked on "Flash Rom".
9. It started doing things and after about 10 seconds it threw an error "Error File Download".
10. So I clicked on Erase NAND (IDB) again to erase the partition and start again.
11. Clicked on Flash ROM again and it threw an error immediately "Error File Download (IDB)".
So then I started to panic and stupidly decided to try power cycling my J22. Now I am unable to get my Windows PC to see the device plugged into it. So am I out of luck and just bricked this device for good? Or do I have some options here to try?
Thank you for your time.
EDIT: So I guess I was slightly pre-mature on saying I couldn't get the J22 device to be recognized by windows. I found a youtube video where a guy shorted some pins on his hardbricked android device and was able to get it working again. So I thought what the hell? why not try it? It worked! I just used a paperclip to short out random pins on the nand flash chip until the blue light blinked. I then unplugged it, then plugged it back in and bam! windows recognized it again. So Now my question is, what did I do wrong before and how can I get the finless rom installed properly?
