Webcam issue
    Webcam issue
    I have a MK908 with finless 1.6 rom on, and... it can't recognize the webcam.
    I bought a logitech c170 (included in the compatibility list) and connected on usb port, but nothing happen.
    If I try a video call from skype it crash and the same happen if I use mic or camera app.
    I also tried with a logitech 9000pro but it does the same thing.
    Anyone can help me?
    Thanks in advance
    Anyone can help me?
    Thanks in advance
    I found my C170 only works by plugging into the standard USB port (MK908II & MK808B), it does not work if I use the OTG port.
      i tryed in both OTG and USB but nothing change
        no one can help me?
          Did you try change firmware?
            Logitech c525hd doesn't work in any 908 firmware.
            I can get sound from mic and slow-rate picture, but it is unusable.
            See this topic for details:
              Webcam use lot of power, by knowing that you should be using a powered usb hub. It is also true when using usb disk. It may not solve problem but it could be the problem.
              T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
                Via powered hub, OTG and host-usb results are the same...
                  not yet
