mk802iiis dont boot after flash
Flash the original ROM back onto the device... Then before you flash anything else you need to open it up and verify which version specifically you have... different ones use different chipsets on the wifi/bt specifically and because of that may use slightly different flashing instructions.
To get an idea of what I'm referring to... read through some of the MK808/808b Clone thread... it will help you understand which chipsets you need to be looking at on your own device.
There are currently 2173 users online. 2 members and 2171 guests.
