Tronsmart T428 keeps rebooting when app Is launched
Hi I have been using my tronsmart on and off for about 6 months. I plug It In to the tv and power it up just when I want to watch something on the net via the browser or the filmon app that i installed. When I first got It, It was working but then got stuck at the penguins screen each time so i downloaded a new firmware from somewhere on line and It worked since until the other day. It loads up fine and I can usually select the wifi network and add the password etc but then when i try to launch any program it reboots ? I cant remember If It came with an sd card installed but there is not one there ! Is that the problem ? If so I do have a spare one from my old phone ! Or am I missing something ! I have tried about 3 new firmwares now so it must be something other than that like a setting or something.
Tags: None
Originally posted by npire1 View PostHi I have been using my tronsmart on and off for about 6 months. I plug It In to the tv and power it up just when I want to watch something on the net via the browser or the filmon app that i installed. When I first got It, It was working but then got stuck at the penguins screen each time so i downloaded a new firmware from somewhere on line and It worked since until the other day. It loads up fine and I can usually select the wifi network and add the password etc but then when i try to launch any program it reboots ? I cant remember If It came with an sd card installed but there is not one there ! Is that the problem ? If so I do have a spare one from my old phone ! Or am I missing something ! I have tried about 3 new firmwares now so it must be something other than that like a setting or something.
Hi, btw you do have the original power adaptor it's a 2A no great but more effective than a 1A telephone charger like even the iphone charger.
I use a 3A adapter and never had an issueI help with 4GD663269M466950W
And you ????
My devices:
Tronsmart T428 real 3188 with Finless A928 and D33 Kernel at 720p
Tronsmart Prometheus won on CNX just now....
There are currently 2371 users online. 2 members and 2369 guests.
