I've flashed Tronsmart's Android 4.4 beta firmare on my Imito QX1.
Now I'd like to go back to a 4.2 ROM because wifi and bt isn't working.
Unfortunately the 4.4 firmware upgraded the loader to version 2.08.
I am not able to flash ROMs which using 1.24 loader version (no found RKAndroid rock usb).
Flashing procedure of 4.2 ROMs (e.g. Finless ROM 1.5) with loader 2.08 is shown as successful in flash tool. However I don't get HDMI output then. I guess loader 2.08 isn't working with older 4.2 ROMs, is it?
I've found a thread in Minix section. There, in the linked forum, they describing restoring successfully the firmware of Minix X7 by keeping pressed the power button during flashing procedure.
Unfortunately the QX1 don't has a power button.
I am able to bring the QX1 in "MaskRom Rock USB" mode by shorting two pins of the NAND Chip.
Any idea on how to flash Android 4.2 ROMs on my QX1?
Thanks in advance.
Best regard
Rnd
Edit:
Solution:
Don't use Windows 8.1. Old bootloader doesn't work under Windows 8.1.
Then this prodecure works:
2) Erase NAND.
3) Close the KitKat Flash Tool and now run the Flash Tool from the 4.2.2 (Jellybean) or 4.1 whatever ROM.
4) DO NOT erase NAND again. Just flash.
