New MK802IV
    Originally posted by blinkone View Post
    you only use 1 of the parameters iv posted not both of them lol lol either use the 4gb or the 2gb..what rom are you using or trying to flash???you just replace the parameter in the rom you want to flash with one of the ones I posted
    myself i use a 4gb parameter (internal storage)
    & use a 32gb sd card as my nand flash but i think you should walk befor you run so i dont recomend the sd card nand set up for you at this time the 2 GB parameter will proberly do you
    God i didn't make that clear at all, what i intended to say was:-
    Stick the 2GB RAM file into the Ram tab under parameters.
    Then i take the 4GB Storage Parameters and and if i'm thinking correctly that goes in the parameters tab under Nfs?
    The question was whether or not i can make the modification to the RAM at the same time i make the modification to the storage in a single flash process like i outlined above, or do i need to flash twice, once to fix the ram and again to fix the storage?
    And to answer ur question i'm using: Neomode Custom Rom MK802IV as suggested by neomode earlier in the thread, i do much prefer it over the stock rom but a couple of things niggling me but i wanna get the bigger stuff sorted out first
      NO no maybe iv confused things,you only need to change the parameter file (you change one file in the Neomode Custom Rom) & that changes the internal storage & it changes the nand storage
      1.All you do is download the 2gb parameter i posted, save it to your pc (forget about the 4gb one)
      2.open the flash tool click the box iv highlighted in red,now navigate towards the 2gb parameter you downloaded & saved select it.
      3.click erase IDB (nand)
      4.click flash rom
        Right ok, i'm totally lost, the 2GB file u listed originally, will that fix the RAM or how much internal memory i have? sorry for being a pain
          ha ha no worrys I do that to people lol,, the file I posted will sort you out.. it will give you 2Gb of ram (internal stoage) instead of 1gb witch you have now & your nand will be about 5gb
          & to confuse you even more if you was to use the 4GB parameter file i posted insted of the 2GB parameter file, your ram (internal storage)would be 4GB & your nand would be about 3GB
            OMG thats confused me even more, lemme try to clear this up stating the 2 problems one by one.
            1st Problem:- The device says on the box it has 2GB RAM, which the original ROM stated as well
            Neomode's ROM only seems to recognise the 1, i had though the 2GB file u sent me was to fix the RAM issue and make the ROM rcognise that all the RAM is there and available.
            2nd Problem:- Internal storage says 0.98GB Total 123MB Available
            NAND says 5.61GB Total, seems to be stuck calculating the available atm
            No MicroSD atm
            as far as i can tell my apps install to internal storage not NAND
            so i wanna take about 4GB of NAND and put it to Internal Storage, giving me more room to install apps to as i any files i want to store i'll keep them on the microSD card once it's put in.
              also if u have skype and it may be easier to discuss it on there, add whiteknightoftruth lol
                No MicroSD atm
                Yes the 2GB file i posted will put storage back to how it was when you brought it (will fix problem 1 & 2)
                You are right Most app's install the app to the internal storage & a little to the nand..if you install a large game though most of the game will be installed on the nand & a little to the internal stoage,, so your nand needs to be bigger than your internal storage
                  kool, and so it begins lol
                    Yes it would be easer but iv never got around to installing it..it must to on my to do list lol
                      Good luck
                      It all used to go straight over my head when i first started 12 months ago, you soon pick it up the main thing is not to worry & panic most things can be fixed
                      i used to think people on hear was talking an strange alien language I still do sometimes ha ha
                        Good luck
                        i'm generally not too bad when it comes to tech n computers in general but fairly new to android as i got a hudl, then an xperia Z and now this tv pc lol
                          right thats the format n flash done now, 1.97GB Internal Storage, 4.6GB NAND.
                          out of interest WTF is NAND and why do we actually need it, my tablet n phone just have internal and external memory n they run fine?
                            Ha HA don't ask me technical questons like that!!! dev's,mod's & admin "HELP" step in when ever you like ha ha
                            When your feeling brave & iv had lots of asprin i will teach you have to have a 32Gb nand
                            Glad your sorted anyway
                              i think i may have tinkered with that before when i was trying to sort this out, something to do with fstab file in etc??
                                That's the one iv got about 20GB of games installed on mine so i had to edit the fstab for them to fit lol..but on android 4.4 there is no fstab ahhh but bob made me a fix for that
