Okay I am trying to Flash from 4.42 KitKat to 4.22 on a M9 Pro 3G
    Yes read it and still forgot to click the tick LOL but managed to get it on there.
    can i ask if you have the original un-edited 3g pipo ROM and software on your machine, if you do how hard would it be for you to create a Loader package like you have for your custom firmware and ROM with the original software etc. eg make a kit so people can easily return to the Standard un-modified software for warranty purposes.
    Just think people might find it handy and want to have the option of an easier re-flash.
      I can work on it. It would actually be very easy. I'm just away from my PC today. Ill work on it tomorrow.
      Sent from my SAMSUNG-SGH-I537 using Tapatalk
      Randy
        Well that sound good. Thank you for all the help, Updating this tablet once the instructions were shown in the thread is easy. Just need to be able to find the right files. Think the search engine on this site may need a little looking at.
        I have managed to revert back to the original software, I had to try your software worked fine but the battery only lasted about 2 - 3 hours, about half that was using it the other half was just screen off and running background tasks. it lasted about 6 hours last night when the screen was off.
        I have put the original software back on successfully and will look at this battery problem if it still fails to last long. I believe there is software that checks the battery fully, however everything I have tried so far just takes me to the useless system settings battery monitor with no real information.
