Long time lurker, first time poster.
Anyhow, hope I'm posting in the right place! I've flashed Picuntu 4.5 on my T-R42 (v2.0) and it runs smoothly but no networking (Lan or Wifi). Even though my primary machine is Ubuntu my CLI knowledge is limited so used Wicd network manager to try to get Lan working (enabled wired connection as eth0), no good. Tried setting static IP, no good!
After some research it seems the problem is that the default Picuntu kernel does not support the T-R42 chipsets (WLAN+BT: RTL8723AS and LAN: RTL8201F). I tried re-flashing using shaan_npl's kernel (http://www.freaktab.com/showthread.p...l=1#post103354) - No change!
Has anyone compiled a Picuntu 4.5 kernel for T-R42 boxes? I'll happily have a go at compiling my own if Lewy or Wasser can give me the correct .ko drivers for these chipsets unless somebody else has already done it??
On a side note, is it possible to use Picuntu with an android kernel such as Wasser's 1.2.4 for T-R42?
Thanks in advance for any help.
