Need help with a Mk908II Kernel (3.0.36+) for 4.2.x
I am using Finless 1/5a Rom, but I need to make a small change in the kernel in order to properly load a USB device driver, hence I need compile my own kernel.
So far I've been unsuccessful with any that I've tried.
I've tried using the marvin builder, and none of the mk908 kernel source trees work (as I understand due to mk908ii difference from mk908) --
Any help with how to build a working kernel image would be appreciated
Have you been able to build a working kernel for you mk809II since?
I am having the same problem. Kernels built with marvin's source doesn't work.
