Neomode, thank you so much for this. I couldn't find much about the MK808II so when I got my Android player I used the Finless Rom for the MK808B. I worked ok but the wifi was slow and bluetooth wouldn't work. Your rom works great for this device and I'm glad I finally found it. Thanks again and keep up the good work.
Neomode Custom Rom MK808II Version 1.0
thank you
touchscreen not worked properly
I have a MK808II and an AOC e2239fwd touchscreen monitor(quanta optical touch screen).
With the previously stock MK808II rom the touchscreen work properly (after I added the appropriated .idc file in system/usr/idc); with your rom the touchscreen is recognized as touchpad, I can see and move the touch cursors (drawed as white hand gloves) but the touch is not recognized; it's like a touchpad, I can move the cursor(s) but no press.
I try to flash the Finless rom (1.7 and 2.1) for mk808b with your Kernel and the touch works properly, but bluetooth does not work.
(with the Finless i don't see the cursor for touchscreen and the multi touch WORKS)
I also try to flash the NEW stock rom but no touch press.
I had notice that in your rom (and in the new stock rom) there is a hid-multitouch.ko file in system/lib/modules and in the Finless the file is missing.
I try to change the relatives xml files in permission with no luck.
Can you help me?
thanks in advance
There are currently 2430 users online. 1 members and 2429 guests.
