CWM For Allwinner A31 box
    We are pleased to present this version of CWM supporting TVBox MeLE Allwinner A31 family and possibly other devices with the same SOC. This compilation has been developed by MSX2 from androidpc.es and me for all users, we hope you like it and you may be able to take full advantage.
    NOTE: Other devices are not supported.
    CWM for Alwinner A31box
    There are 10 types of people in the world: Those who understand binary, and those who don't...
    If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
    Fits to a A31S?
      Re: CWM For Allwinner A31 box
      Originally posted by fps-dum View Post
      Fits to a A31S?
      i didn't tried in a31s but it will probably work. Give it a try, if it doesn't work, just flash over your rom again.
      Feedback is so much appreciated
        What about Allwinner A31 tablets?
        JDfense
          JDfense
          just try it, if it doesn't work, pm me with a link to your firmware and i'll have a look.
            Okay thanks. I'll check it with my new colorfly e708 q1 tablet, but I need some time. At first I have some other problems with my cs968 to fix and then learn the basic stuff of Allwinner ROMs.
            JDfense
              I did a test.. on mk823 (a31s)
              Installed update.zip.. reboot to recovery.. and navigated abit
              -based recovery by deamonium and mx2 for site
              The bad..
              There is no : Directory-up option (navigate using mouse)( no-way to get back to main screen)
              Unable to boot into android, anymore
              Perhaps you could add a editor.. to make small changes and read the log files?
              Backup and restore > backup to external sdcard
              -i don't think it did anything, les then a sec.. to menu again
              Backup: mount backup path
              Mount and storage: cannot navigate back
              Boot system now: nope.. reboots to recovery again ( same as removing powercord, and powering unit again)
              W log: unable to mount /dev/block/nandh
              Advanced> boot recovery : boots to recovery
                The bad..
                thanks for the feedback, i'm sorry it's not working for you. can you provide a link to your actual firmware?
                  Ohh.. hi
                  If you seek to make custom version then please make one for the CS918S (firmware can be found in this forum)
                  I just installed the update.zip on my mk823 unit.. to analyze the risk
                  -nothing more
                  Cheers.. and keepup the good work
                    Ohh.. hi
                    -nothing more
                    i was asking for the firmware because my intention is to modify this cwm to make it work on mk823. which box do you have? are mk823 and cs918s actually the same box?
                      No.. ( mk823 = stick // cs918s = tvbox )
                      There many users here at freaktab h'own a cs918s box (like me)
                      But the cs918s firmware can be installed on the mk823 (safemodus)
                      -so, if CWM fails on the mk823, it will mostliky also fail on cs918s
                      --cs918s is my star player
                      Cheers
                        http://www.freaktab.com/showthread.php?8841-New-CS918S
                        Cheers
                        ok then i'll go for cs918s
                          This is my first attempt to make cwm work for CS918s , hope it will work
                          CWM
                          https://dl.dropboxusercontent.com/u/346057/CWM_for_CS918s.zip
                          App for reboot
                            https://dl.dropboxusercontent.com/u/...for_CS918s.zip
                            Any instruction that how to install this would help?
                              Yes, sorry i forgot that :P
                              - Copy the zip file and reboot.apk in a USB memory
                              - Install the app reboot
                              - Run the upgrade system app in your A31 box
                              - Search for LOCAL updates
                              - Execute local update
                              - The system will reboot
                              - After reboot, use the app to reboot into recovery mode
