Pipo S1 Pro flash mode? [SOLVED]
    Hey all,
    Does anyone know how to put the Pipo S1 Pro into firmware upgrade (flash) mode? I've tried the sequence for the S1 (Vol - button & reset), but it doesn't work.
    I've had a look through the forums, but can't find anything about it. Someone must know!
    Any help would be gratefully received!
    -Mark.
    Try volume + power.
    Sent from my M7Pro
    Randy
      Sweet! All working...
      Thanks Randy.
      It must have been the only combination I hadn't tried!
      Now to restore a clear firmware... and we get to see if the charging issue is firmware related or hardware (please be firmware..)
      Thanks again.
