CWM Recovery with UBIFS Support For Amlogic Nextbook Tablets
    This thread contains links to CWM Recovery with UBIFS support for Amlogic based Nextbook Tablets. These are built from CM10 source, with Amlogic and UBIFS support forked from the Github repos of Christian Troy and Librehat. Thanks to both of them for sharing their source code! I plan to publish my Nextbook changes, once I learn more about the use of Github.
    I will be adding custom versions to this thread for additional tablet models as I get them compiled and packaged with the proper kernels, etc.
    Please make sure you download the correct version for your device!
    While some versions may work on other tablets, differences such as partition layouts that are hard coded into the kernel could cause a flash to fail and brick your tablet. Because of this, I can not support the use of a custom recovery on a device that it was not intended for.
    These files will be named in the format: "model"-"board"-CWM.zip
    Verify these entries in your stock build.prop before downloading: ro.product.model and ro.product.board
    Installation:
    1. Download the appropriate version for your device below
    2. Unzip the downloaded file
    3. Remove the uImage_recovery file and place it in the root level of your external SD Card
    4. Insert External SD Card in your device
    5. Power on device while holding volume-
    6. PERFORM A BACKUP!!! This will backup everything except your bootloader.
    Downloads:
    (Obsolete - Links Removed)
    Check back here later for more devices...
    Support Thread:
    CWM-Recovery-with-UBIFS-Support-For-Amlogic-Nextbook-Tablets-(Support-Thread)
    ShaunMT
    Last edited by shaunmt; 23 August 2014, 06:21. Reason: Added Download Link For Next8HD-8G-NXM8000NBD_WMN-CWM.zip
    Freaktab Rom Developer
    TWRP Is Now Available For Multiple Amlogic Based Nextbooks
    TWRP-Recovery-with-UBIFS-Support-For-Amlogic-Nextbook-Tablets-(Download-Thread)
    I am no longer supporting CWM on this model.
    ShaunMT
