Root tsintech i30
    Root tsintech i30
    Finally I could make root the i30 tsintech Android tablet.There is no program that can do it. The only way is flashing the tablet.
    First of all there is something you have to know: there are two different i30 model: a VGA (800x480) and a SVGA (1024x600). It's it show in the kernel compilation serial number.
    The VGA is identical to the Penta W708c. So the way to root is flashing a Penta ROM ( http://www.freaktab.com/showthread.p...C-RileyROM-1-0)
    The SVGA there is no customised ROM, so the only way is flashing just the system.img (and the other configuration files) from the i30 ROM (http://www.freaktab.com/showthread.p...0-RileyROM-1-0)
    This tablet is also selling with other names (gpad), but internal is the same.
    I hope this could be a usefully information.
    Enviado desde mi iPhone con Tapatalk
    please link me tsintech i30 480*800 rom ws708c
    thanks alot
    is it rooted?
    are you sure?
      Try the ROM here: http://www.freaktab.com/showthread.p...0-RileyROM-1-0
      If you can use the kernel.img from the Penta ROM is the resolution doesn't work for your tablet.
      Let's pick and thread, and continue the discussion in ONE PLACE. No need in having the same conversation on 3 different threads, please...it's confusing.
      Randy
        excuse me sir
        ok
        please assemble this rom for me
        thanks
        my tablet resoulation is 480*800
        it is my tablet
        Code:
        http://www.pantel.in/DriverDownloads
        ws708c
          I'm downloading it now. Give me a bit and I'll make a ROM for you.
          Randy
            Thanks alot
            i am waiting for you
            you are very nice man
            thanks you
              I'm uploading now. As soon as it's done I'll give you a link to try it.
              Randy
                OK, here you go:
                See if this works. If not, I have another system.img we can try.
                Randy
                  my tablet is 480*764 screen resolution
                  does it have a cwm recovery?
                  is it root?
                  thanks mr
                    Just in case you have any problems, just re-flash with this system.img file. It is just a rooted version of the stock file:
                    Randy
                      Thanks a lot
                      Your rom didnt work with your rom
                      Unfortunately my tablet will not be turn on
                      I should flash with my stock rom
                        I downloaded the firmware you sent earlier...that's what I used for the ROM.
                        Change the parameter to "parameter2", erase IDB and flash. The 4gb default may be the problem.
                        Randy
                          Whatrileypm;143502]I downloaded the firmware you sent earlier...that's what I used for the ROM.
                          Change the parameter to "parameter2", erase IDB and flash. The 4gb default may be the problem.[/QUOTE]
                          Excuse me sir
                          What do I do now?
                          Please talk me more explain
                          I am amautor
                          Please give me final link
                            If you have already flashed the ROM, you know the basic steps.
                            In the RileyROM folder of the ROM kit, you will see the elements of the ROM files.
                            You have several parameter files. The "parameter" file is defaulted to 4gb for user app space. Delete that file and rename the file named "parameter2" to "parameter".
                            Flash the ROM again with that setting and see if the tablet boots.
                            Randy
                              thanks sir
                              i know flashing rom but ynfortunately i dont understand when you say rename parameter
                              should i replace or rename?
                              can you assemble all of the patametr in one file and then uploade it
                              thanks alot
                              You are so good and kind
