I am putting a basic rom together. Removing all the bloat.
So far i have removed all the bloat.
Installed Kit Kat launcher
Standard Build.prop changes
I will be working on overclocking next. I will have both stock kernel and overclock kernel....
FYI....I use active cooling with a fan and i use a usb to Ethernet adapter so i am not testing wireless as it is junk anyway. I also have a Logitech camera that i can confirm that works.
I will include CWM update.zip also all the gapps.zip that i used and know that works.
I dont care much about the boot animation...keeping that the same.
What else should i include?????? Tying to keep it lean and mean.
I anticipate about 1 more week before i upload it.
