Ican reinstall that?
xbmc help
Originally posted by SilentBob View PostAll xbmc apk's are on their website http://xbmc.org/download/
Mine didn't and neither do the Finless roms (which I flashed immediately after purchase).
But then again, I squeezed my stick between 2 fans and use an overclocked rom, just to get xbmc running smoothly at 1080p.
I've noticed some vendors sell sticks with xbmc pre-installed for an extra cost. I think they either install an xbmc beta (nightly build) or the xaf version based on mx-player. I get the best result with xbmc nigthlies.
Grtz,
B
xbmc-ouya
Originally posted by TPXX View PostI have a stock cx-919 and tried to update xbmc. it no lomger works. Does anyone have the stock xbmc apk so
dood i have the mk908 v5 and the xbmc-ouya .apk file works for me very well just google aroun for it or down from my link http://www.mediafire.com/download/9g....3.2.apk:BACON
Try BeyondXBMC. It works great on my cx-919
Originally posted by TPXX View PostThanks guys, I'll try the nightlies or the ouya and see if they work
Originally posted by tech4d View Post
beyondxbmc works very well
new gotham 13 beta1 works very well too, and support mouse scroll like beyondxbmc and external player
you can use this two in same device to try, it install their files in different directories, and keep that you like !
PD: to not loose your configurations, backup userdata folder or (my case) .xbmc folder
regards
There are currently 1646 users online. 1 members and 1645 guests.
