MK 809 ii
    MK 809 ii
    Hi
    I need help, I'm going crazy :-(
    I have mk 809ii with 4.2.2 rom. I had a problem with it and tryed to flash Finless rom 1.7a. In the process I lost power and flashing stopped and now I'm stuck. I can't flash new rom. I was looking online for solution and I can't fiy it. When I use RKAndroid tool and click erase NAND I get: INFO : Doing lower format, Total (2048), current (7). When I first tryed to flash it formated all of 2048, now is stuck on 7. I also ger error : Download IDB fail.
    Please help me, I don't know what to do...
    Picture of my device :
ID:	439053Click image for larger version
    Originally posted by Ivan2000 View Post
    Hi
    [ATTACH=CONFIG]5221[/ATTACH][ATTACH=CONFIG]5222[/ATTACH]
    You need to short pins 7&8 on the nand chip wile plugging it in to the pc that will enter it into maskrom mode ,then flash it
      I have shorted the pins and in Finless rom flash tool I got Found RKAndroid maskrom rock usb. I clicked on erase nand and i got that erasing IDB ok. The i tryed to flash rom and i got error : download IDB fail
      I noticed that in device manager ( win 7 ) i have under Class for rockusb device - rockusb device - there I have question mark. And it says that best driver is installed ...
      It semes I done it :-)
      Now i have 2 pengiuns and I'm waiting to boot up
      Batch tool log:Loading firmware...Loading firmware Finished.
      Loading firmware...
      **********Restore Action**********
      **********Restore Start Total<1>**********
      <Layer 5-1-4> Download Boot Start
      <Layer 5-1-4> Download Boot Success
      <Layer 5-1-4> Wait For Maskrom Start
      <Layer 5-1-4> Wait For Maskrom Success
      <Layer 5-1-4> Test Device Start
      <Layer 5-1-4> Test Device Success
      <Layer 5-1-4> Check Chip Start
      <Layer 5-1-4> Check Chip Success
      <Layer 5-1-4> Get FlashInfo Start
      <Layer 5-1-4> Get FlashInfo Success
      <Layer 5-1-4> Prepare IDB Start
      <Layer 5-1-4> Prepare IDB Success
      <Layer 5-1-4> Download IDB Start
      <Layer 5-1-4> Download IDB Success
      <Layer 5-1-4> Reset Device Start
      <Layer 5-1-4> Reset Device Success
      <Layer 5-1-4> Wait For Loader Start
      <Layer 5-1-4> Wait For Loader Success
      <Layer 5-1-4> Lowerformat Device Start
      <Layer 5-1-4> Lowerformat Device Success
      <Layer 5-1-4> Download Firmware Start
      <Layer 5-1-4> Download Firmware Success
      **********Restore Done Success<1> Fail<0> Time<126346>ms**********
        I dont think its a driver problem but it may be, it could even be a bad lead your using to flash it,i think it more that likly the wrong rom your trying to flash as that dont look like a mk809ii to me its not the same as mine so i would try other roms..I found this to be the best rom for my mk809ii but you will have to wait for it to be uploaded again as some bad man deleted it sorry
          I have tryed putting finless 1.7a rom and when I connect it to tv, tv does not have signal from the hdmi port :-(. Then I tryed with rkbatch tool to put MK812 firmware and device booted, wifi is working ok but I can't use any more measy rc12 wireless keyboard...
          Any idea what to do next?
          It's driving me crazy
