error
    error
    I was restoring an application and the tablet was left hanging at restart get this message:
    uids inconsistent system
    uids on the system are inconsistent, you need to wipe your data partition or your device will be unstable.
    I'm feeling lucky.
    Any idea?
    There is something wrong with your NAND format. There are a lot of causes for that.
    If you flash a ROM without erasing IDB is one cause. Also if you go back and forth between KitKat and Jellybean there are some steps. You have to take (see the thread on that in the Pipo section).
    Or you could have a bad NAND chip.
    Since its an isolated problem, it likely isn't the ROM.
    Sent from my SAMSUNG-SGH-I537 using Tapatalk
    Randy
