CX919 new stock firmware fix flickering issue.
Originally posted by edgar28 View Posthttp://blog.geekbuying.com/index.php.../#.UviXovtqN0o
anyone try it yet?
Downloading right now.
How does it compare with Bob's 1.5?
AW: CX919 new stock firmware fix flickering issue.
Originally posted by avdw77 View PostDoesn't flicker, but wifi doesn't work at all. Can't enable it. I have a CX-919 V2.0
_________________________
tapatalked from GalaxyS3
Originally posted by FadeFx View PostIf you have a cx-919II (the one with dual antenna, never heard of a v2 yet) this firmware isnt for you at all...
CX-919 has V2 (not cx-919 II)
it's new version I believe it's with the new WIFI chip
as I see they upload a new firmware that solves the wifi problem
I tried this firmware on my cx-919 ver 2.0 and can report the cpu does scale from 312-1.6ghz as reported by cpuz and Antutu.
I had no luck in rooting it so I extracted the kernel and am running it on finless 1.6b with no flickering, wifi works, bluetooth turns on but I have not tested it as I do not use it.
I also patched the extracted kernel with overclockomatic script and had no success with any further overclocking on any of the patched kernels.
Originally posted by vrm71 View PostI tried this firmware on my cx-919 ver 2.0 and can report the cpu does scale from 312-1.6ghz as reported by cpuz and Antutu.
Hi! is there any chance you could share the stock kernel you extracted from the firmware? =) thanks in advance
Originally posted by hellrazor219 View PostHi! is there any chance you could share the stock kernel you extracted from the firmware? =) thanks in advanceAttached Files
Originally posted by vrm71 View Posthere is the new kernel with vsync patch.Nikon D80 Photographer
Eye for the Art.
__________________________________________________ ________________________
CX 919 - Rockchip RK3188T 1.4 GHz & AP6210 WiFi ( Date 3-3-2014) + Tronsmart TSM01 Rom using: Testing.
Originally posted by vrm71 View PostYes, it is a 720p kernel.Nikon D80 Photographer
Eye for the Art.
I will do a ROM based on this on the weekend!
Stay tuned.
There are currently 2695 users online. 0 members and 2695 guests.
