ps connected with hdmi lead.
neo x7
neo x7
hope some1 can help me here im just getting used to the x7 now i have beyound xbmc 3,3 beta on it i have all my plugins working so im pleased with it even got mashup 1.0.4 working, the problem i have now is icloudtv i dont have any sound on any of the channels,my x7 is running thruogh a yamaha av hdmi i get sound on everything running through the is it r29 k something loopthrough so i get surround sound where ther is . ive been into setting but cannot find anything that will make it work any help please. plus the picture on some of them have the black line down each side why is this, the mx3 was not like that so again any advice with that please.
ps connected with hdmi lead.Tags: None
still new to this box and not had much response. ive been looking on the forum for a guide how to move the widgets i seen a video on youtube but cannot find it now any help please. plus i have a qwerty keyboard touchpad usb,the booklet i got does not show you how to work ie function buttons does anybody use 1 and any advice please. is it possible to expand it with usb/sd card if so how big can i go can i expand to 32/64 gb and do i have to mount it because i have some apk games can i put them on any of the devises. and how can i back up the image i have on now and save it to pc if i was to try different image. thank you
well i dont seem to be getting a lot of help here , i need advice how can i back up the image i have on the x7 now the qwerty keyboard touchpad usb. ive been on google to find instructions no luck, and can i expand to 32/64 gb sd card or put ipk files on it cannot remember now but on a hard drive i have load of ipk files that i used to sideload on a bb z10 so it would work like a android can i use them. or would i be beste to mount usb hd and use that just need some advice or some guides please.
There are currently 2071 users online. 0 members and 2071 guests.
