I'm from Brazil and I follow this forum for some time, and here already managed to learn a lot from you.
I'll try to be as detailed as possible for maximum ease who want to help me.
I know you will say that there is a post in the forum about this, but there have not found any like my MK808.
In this post I have not found anything. http://www.freaktab.com/showthread.p...-identify-them
I want to find out which is able to find a ROM that works for me I damaged it.
Understand what I did:
I bought several MK808 "ORIGINAL" as the first of the above post made by friend "leolas".
I use the MK808 for indoor digital media, and how it does not have a physical button for safe shutdown, it corrupts the rom often.
To not have to do all the setup work whenever he corrupts I chose to do a backup with CMW 6.0.3.1 downloaded at this site:
http://androtab.info/clockworkmod/rockchip/rk3066/
Since then, whenever there was a problem, was sufficient to restore the backup I made from my Original MK808.
So I bought 2 more MK808 (internal chip: MEDIATEK MT5931SA) with another seller, not open to check the version of "I know I was stupid
.gif)
I followed the tutorial from this site: http://forum.xda-developers.com/show....php?t=2084906
to solve the problem and could not, so I thought the rom was in trouble and decided to start from scratch.
I installed the rom stok this site:
http://blog.geekbuying.com/index.php.../#.UvuRZvldWT8
And there was NO WI-FI.
Then I thought, I still have hope. Can I make a Backup Stock Rom of the second MK808 FAKE and restore that gave this problem in WI-FI.
So I installed the CMW 6.0.3.1, but I CAN NOT BACKING UP because it crashes, restarts often.
I installed an older version CMW 6.0.2.8, but the problem continues.
So now I DO NOT KNOW WHAT TO DO.
And my current situation is:
>>>> MK808 FAKE > #1
* CMW 6.0.2.8 works OK,
* MK808 ORIGINAL Stock Rom, works but no WI-FI
* I tested some other Roms but it is on the screen with two penguins.
>>>> MK808 FAKE > #2
* CMW's 6.0.2.8 not working, I can not back up, and crashes often.
* Installed ROM is the official 4.2.2 and the WI-FI is OK.
01 - Can anyone help me find a solution to fix the two FAKE MK808 and how do I back them up with the Originals?
02 - Where to find an Official or Custom Rom that works on it?
03 - How do I fix the problem in the CMW MK808 FAKE # 2?
Below are some images I have to help identify the model.
(can't upload picks now, more later i post)
Many thanks to all who have had the patience to read and help me.
and already I apologize for my English by Google.
